Set subassembly to flexible by ilogic.
gma
gma
Is it possible to always set a assembly to flexible... So when i put it in an assembly, it will be standard flexible.
If not.
Is it possible to make an ilogic so when I put a subassembly into an assembly, I can run a rule so every subassembly starting with "StandardLeg" will be flexble?
Thanks in advance.
JhoelForshav
@gma
I don't think you can make the subassembly always flexible on place... You can however run this code in the main assembly after you've placed your components to make the subassemblies starting with "StandardLeg" flexible :slightly_smiling_face:
Dim oAsm As AssemblyDocument = ThisDoc.Document
For Each oOcc As ComponentOccurrence In oAsm.ComponentDefinition.Occurrences
	Try
	If oOcc.Definition.Document.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject _
		AndAlso oOcc.Name.StartsWith("StandardLeg") Then oOcc.Flexible = True
	Catch
	End Try
Next
gma
Solved
Thank you very much
