Set position of detail view leader
philipp.rockenschaubDDSYJ
Is there a way to change the position of the leader text for detail views with iLogic?
I have code that changes the size of the detail but the leader text stays relative to the centre.
Inventor version is 2019.
bradeneuropeArthur
Where do you prefer to have the text?
Could you make an example with a normal leader text to have an idea?
Arthur Knoors
Arthur Knoors
Autodesk Affiliations:
I want it to stay in the same position relative to the top right corner (like in the picture above).
Right now when I resize the detail, the text stays relative to the centre
bradeneuropeArthur
You mean that if the rectangle is moved larger the leader and text are not moving with the move outside too.
Your question is about the text with the leader and not the text only, right?
Arthur Knoors
Yes.
When I resize it it goes from this:
to this:
But I want the name of the detail to stay above the top right corner:
