Set option create independent bodies on failed boolean in iLogic rule
Darrell.johnson
Darrell.johnson
Does anybody know how to set the option "create independent bodies on failed boolean" in an iLogic rule?
Is there a memeber for this command (oDerivedAssemblyDef.???)?
Thank you in advance
Mark.Lancaster
@Darrell.johnson
Welcome to the Autodesk User's Community..
Programming questions and issues should be posted in the Inventor Customization forum for best results
https://forums.autodesk.com/t5/inventor-customization/bd-p/120
I will have the moderator relocate your posting there to better suite your needs.
Mark Lancaster
AlexFielder
Have you tried this:
oDerivedAssemblyDef.IndependentSolidsOnFailedBoolean = True
(from the documentation)
Darrell.johnson
@AlexFielder
It worked.
Thank you very much!
