Set Document by location of rule
J-Camper
J-Camper
I am setting up a part with a local ilogic rule and I want the rule to run when I update value from parent assembly rule.  How can I define the Document that the local rule is in when said document is not the active document?  I thought "ThisDoc" was supposed to do that , but it doesn't seem to work at all.
The way the local rule is set up, If the quantity parameter is changed it should fire.  I want to be able to change the Parameter from an assembly rule, which controls multiple parts.
The rule works from the part level using "ThisApplication.ActiveDocument"  but won't work if the parent assembly is changing the parameter while it is active.
JelteDeJong
Just a quick note. You are wrote that "thisdoc" does not work. did you also try "Thisdoc.Document" or just "Thisdoc"?
can you share your code?
Jelte de Jong
Blog: hjalte.nl - github.com
J-Camper
Okay, I feel stupid now.  Didn't realize I needed to say ThisDoc.Document... Thank you
