Set a value in "QTY" Bomlist
gma
gma
I have this Ilogic code to find "BandL in subassembly''s in my assembly :
Dim total As Double = 0
Dim adoc As AssemblyDocument = ThisDoc.Document
For Each occ As ComponentOccurrence In adoc.ComponentDefinition.Occurrences
        Dim val As Double
        Try
               val = Parameter(occ.Name, "BandL")
               total = total + val
        Catch
        End Try
Next occ
MessageBox.Show("Total length: " & total)
I need to set the "Total" in to a "Part" QTY in my assembly bomlist.
The filename of the part is different, it depense of witch type i need. But the part filename contains S1100 or S2400 and it is a content center file
How do I do that?
Regards
GM
JelteDeJong
You could set "Base Quantity" in your parts to the parameter "BandL"  (Tools -> Document Settings)
then inventor will automaticaly set the total value in the "QTY" column.
Jelte de Jong
Blog: hjalte.nl - github.com
gma
"BandL" comes not from a part. It comes from a rule(parameter) in a subassembly.
I Count alle the "BandL" manuel in the subassemblys and set the total value in the bomlist in my top assembly.
I need a rule for that.
JelteDeJong
A part or (sub)assembly is not different. Also the "Base Quantity" in a (sub)assmbly can be set to a parameter "BandL"
Jelte de Jong
bshbsh
and why do you do that? why don't you use the merge function in the bom?
