Server error for unknown reason during check-in Vault 2019
Hello, guys.
An assemble that had no trouble thus far, I've got this message now while I proceed check in.
Could you help me?
Replies (9)
bradeneuropeArthur
hi,
uncheck the dwf creation on check in...
Arthur Knoors
Autodesk Affiliations:
How can I uncheck the DWF file? I can't seet it on Vault.
I tried to undo check out, but the message of error remains the same.
bradeneuropeArthur
In the vault options dialog settings.
Arthur Knoors
bradeneuropeArthur
Within inventor!
Arthur Knoors
JamieVJohnson2
Inventor - Vault Add-in has a prompt options (Vault Ribbon\File Status section \ Vault Options \ .Check In dialog, Settings...  \ Visualizationg Attachment Options \ Do no create.  You can set a prompt option to do that (done so in the past), but if you're not careful you may default yourself out of the options you want.
jvj
I have accessed those dialog boxes, but the message of error persists.
bradeneuropeArthur
Maybe you try to edit a Library file with the Vault project file.
Since this is not possible you receive this error!
Opening and editing library files needs to be done with a separate project file.
Is this the case for you too?
Arthur Knoors
david_coulam
Does this have to do with special characters (international?) like this issue for prior versions of Inventor?
david_coulam
Also, make sure the Vault file store folder is not full.
