sequence number before actions at Browser list
does Inventor have the function that shows the sequence umber before actions at the browser panel?
like the below picture shows:, this will helps me a lot to modify the a big file which may has hundreds steps. thanks.
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
Renaming Browserlist is same as renaming PartFeature. So, try below VBA code to rename Features with sequence number.
Sub Main()
    Dim oDoc As PartDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oDef As PartComponentDefinition
    Set oDef = oDoc.ComponentDefinition
    Dim oFeature As PartFeature
    Dim i As Integer
    i = 1
    For Each oFeature In oDef.Features
        oFeature.Name = i & "_" & oFeature.Name
        i = i + 1
    Next
End Sub
Note: if you delete any feature, sequence number will not be consistent.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
