Sending email using outlook express
isocam
isocam
I am trying to write a automatic email using Visual Basic 6, to run inside Inventor, as a part of an automatic registration.
There are two problems, firstly, I want to be able to get text1 and text2 on separate lines and secondly I need to send the email silently (without seeing outlook express)
Can anybody help me sort this out ?
Thanks in advance
IsoCAM
Hi isocam
If you use Outlook, then you can access the exposed MAPI.
I have a module that reads mails and sends mails, make sure you load the reference to Outlook in tools, references than you should be able to pick your way through the scripts i have attached. any problems just let me know.
