Send BOM contents to Listbox...
Good Morning Everyone
I am busy creating a custom BOM Plotter for our company. I am struggling to get it to work. In my application i get the selected main assembly's file path.
What i need to do next is get all the BOM Items in the main assembly and send them to a Listbox with each one's file path.
I Then need to get each file's IDW in the list box. And then use the print option. (Which i will figure out myself.
Any help will be appreciated
Example Code below
Public Class Form1
    Dim _invApp As Inventor.Application
    Dim _started As Boolean = False
    Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
        ToolStripStatusLabel2.Text = ""
        Dim workfolder As String = "C:\Inventor Workfolder\Projects\"
        OpenFileDialog1.InitialDirectory = workfolder
        OpenFileDialog1.ShowDialog()
        ToolStripStatusLabel2.Text = OpenFileDialog1.FileName
    End Sub
    Private Sub Button2_Click(sender As Object, e As EventArgs) Handles Button2.Click
        Dim m_inventorApp As Inventor.Application = Nothing
        ' Try to get an active instance of Inventor
        Try
            m_inventorApp = System.Runtime.InteropServices.Marshal.GetActiveObject("Inventor.Application")
        Catch ex As Exception
        End Try
        If m_inventorApp Is Nothing Then
            Dim inventorAppType As Type = System.Type.GetTypeFromProgID("Inventor.Application")
            m_inventorApp = System.Activator.CreateInstance(inventorAppType)
        Dim oDoc As AssemblyDocument
        Dim oBOM As BOM
        oDoc = m_inventorApp.ActiveDocument
        Dim oAsmDocMasterLOD As AssemblyDocument
        oAsmDocMasterLOD = m_inventorApp.Documents.Open(ToolStripStatusLabel2.Text, False)
        oBOM = oAsmDocMasterLOD.ComponentDefinition.BOM
        oBOM.StructuredViewFirstLevelOnly = True
        oBOM.StructuredViewEnabled = True
    End Sub
Replies (0)
