Send BOM contents to Listbox...
12:32 AM
- Mute
- Permalink
- Report
Good Morning Everyone
I am busy creating a custom BOM Plotter for our company. I am struggling to get it to work. In my application i get the selected main assembly's file path.
What i need to do next is get all the BOM Items in the main assembly and send them to a Listbox with each one's file path.
I Then need to get each file's IDW in the list box. And then use the print option. (Which i will figure out myself.
Any help will be appreciated
Example Code below
Public Class Form1 Dim _invApp As Inventor.Application Dim _started As Boolean = False Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click ToolStripStatusLabel2.Text = "" Dim workfolder As String = "C:\Inventor Workfolder\Projects\" OpenFileDialog1.InitialDirectory = workfolder OpenFileDialog1.ShowDialog() ToolStripStatusLabel2.Text = OpenFileDialog1.FileName End Sub Private Sub Button2_Click(sender As Object, e As EventArgs) Handles Button2.Click Dim m_inventorApp As Inventor.Application = Nothing ' Try to get an active instance of Inventor Try m_inventorApp = System.Runtime.InteropServices.Marshal.GetActiveObject("Inventor.Application") Catch ex As Exception End Try If m_inventorApp Is Nothing Then Dim inventorAppType As Type = System.Type.GetTypeFromProgID("Inventor.Application") m_inventorApp = System.Activator.CreateInstance(inventorAppType) End If Dim oDoc As AssemblyDocument Dim oBOM As BOM oDoc = m_inventorApp.ActiveDocument Dim oAsmDocMasterLOD As AssemblyDocument oAsmDocMasterLOD = m_inventorApp.Documents.Open(ToolStripStatusLabel2.Text, False) oBOM = oAsmDocMasterLOD.ComponentDefinition.BOM oBOM.StructuredViewFirstLevelOnly = True oBOM.StructuredViewEnabled = True End Sub
