Selection using c#
p_krola
Selection using c#
p_krola
I have a problem with selecting an item using c#
public void SelectBody()
            Face selectedBody = Pick(kPartFaceFilter);
            MessageBox.Show(selectedBody.ToString());
            MessageBox.Show("Select body");
        public Face Pick(SelectionFilterEnum filter)
            bool bStillSelecting = true;
            InteractionEvents oInteractEvents = inventor.CommandManager.CreateInteractionEvents();
            oInteractEvents.InteractionDisabled = false;
            SelectEvents oSelectEvents = oInteractEvents.SelectEvents;
            oSelectEvents.AddSelectionFilter(kPartFaceFilter);
            oInteractEvents.Start();
            do
                inventor.UserInterfaceManager.DoEvents();
            } while (bStillSelecting);
            ObjectsEnumerator oSelectedEnts = oSelectEvents.SelectedEntities;
            oInteractEvents.Stop();
            oSelectEvents = null;
            oInteractEvents = null;
            return (Face)oSelectedEnts;
JelteDeJong
If I'm correct then you just want to select a face of a part. Why don't you use the built-in pick tool?
Face selectedBody = Inventor.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Select as Face")
Jelte de Jong
Blog: hjalte.nl - github.com
p_krola
Currently I am converting the Fusion 360 add-in to an invetror add-in. I would like to get the same effect as in Fusion. After pressing the button, the user has the option of selecting e.g. face.
p_krola
I almost solved this problem. I can't select the model when add-in running.
Zach.Stauffer
It looks like your dialog box is modal, if you're calling it using .ShowDialog() try .Show() instead.
p_krola
Thank you very much. I spent about 2 hours looking for a solution and it was so easy 🙂
