Selecting Ordinate Dimension Members using Select Set
inulobo
inulobo
Is there a way to use the select set selection box to grab only the members of an ordinate dimension set that are in the selection box? I am trying to find a way to select a few then do something then select a few more different members and do something. I do not want to do something to the entire set.
inulobo
Here is a picture of what I mean
Is there a way to get the start point and endpoint of the selection?
JelteDeJong
this rule will let you select ordinate dimension
Public Class ThisRule
    Sub Main()
        Dim oSelect As New Selector
        Dim selectedItems As ObjectsEnumerator = oSelect.Pick(ThisApplication)
        If selectedItems Is Nothing Then Return
		' selectedItems holds all of your Ordinate Dimension
        Dim oSelSet As SelectSet = ThisApplication.ActiveDocument.SelectSet
        oSelSet.Clear()
        For Each oFace In selectedItems
            oSelSet.Select(oFace)
        Next
    End Sub
End Class
Public Class Selector
    ' taken from:
    ' https://adndevblog.typepad.com/manufacturing/2016/07/filter-out-faces-not-facing-the-user.html
    Private WithEvents oInteractEvents As InteractionEvents
    Private WithEvents oSelectEvents As SelectEvents
    Private bStillSelecting As Boolean
	Private Sub oSelectEvents_OnPreSelect(
                ByRef PreSelectEntity As Object,
                ByRef DoHighlight As Boolean,
                ByRef MorePreSelectEntities As ObjectCollection,
                SelectionDevice As SelectionDeviceEnum,
                ModelPosition As Point,
                ViewPosition As Point2d, View As Inventor.View)
		'here we check if a selected item is of the type OrdinateDimension
        If Not TypeOf PreSelectEntity Is OrdinateDimension Then
            DoHighlight = False
            Exit Sub
        Else
            DoHighlight = True
        End If
    End Sub
    Public Function Pick(ThisApplication As Inventor.Application) As ObjectsEnumerator
        bStillSelecting = True
        oInteractEvents = ThisApplication.CommandManager.CreateInteractionEvents
        oInteractEvents.InteractionDisabled = False
        oSelectEvents = oInteractEvents.SelectEvents
        oSelectEvents.WindowSelectEnabled = True
        AddHandler oSelectEvents.OnPreSelect, AddressOf oSelectEvents_OnPreSelect
        AddHandler oSelectEvents.OnSelect, AddressOf oSelectEvents_OnSelect
        AddHandler oInteractEvents.OnTerminate, AddressOf oInteractEvents_OnTerminate
        oInteractEvents.Start()
        Do While bStillSelecting
            ThisApplication.UserInterfaceManager.DoEvents()
        Loop
        Dim oSelectedEnts As ObjectsEnumerator
        oSelectedEnts = oSelectEvents.SelectedEntities
        If oSelectedEnts.Count > 0 Then
            Pick = oSelectedEnts
        Else
            Pick = Nothing
        End If
        oInteractEvents.Stop()
        oSelectEvents = Nothing
        oInteractEvents = Nothing
    End Function
    Private Sub oInteractEvents_OnTerminate()
        bStillSelecting = False
    End Sub
    Private Sub oSelectEvents_OnSelect(
            ByVal JustSelectedEntities As ObjectsEnumerator,
            ByVal SelectionDevice As SelectionDeviceEnum,
            ByVal ModelPosition As Point, ByVal ViewPosition As Point2d, ByVal View As Inventor.View)
    End Sub
End Class
Jelte de Jong
Blog: hjalte.nl - github.com
inulobo
Thank you but that's not exactly what I'm looking for. I don't want an ilogic rule. I want to do this is vba using API. In any case, I could not get your code to work. Thank you for the suggestion though.
