Selecting occurrences of an assembly in a drawing
anavazquez5LRNJ
anavazquez5LRNJ
Hi, I have been working on creating automated dimensions but I would like to create dimensions every time you click on any part of the subassembly that needs to be dimensioned, but in order to do so I need to have the name of the subassembly and from there get the workplane, here my question I have found this code in the forum but I can not get the name of the subassembly but I get the occurrences that are within it, is it possible to get the name of the subassembly as such?
Sub Main
    Dim oSelect As New clsSelect
    oSelect.SelectOccurrence(ThisApplication)
    Dim oOcc As ComponentOccurrence = oSelect.SelectedOcc
    oSelect = Nothing
    Dim docName As String = oOcc.Definition.Document.FullFileName
    MessageBox.Show(oOcc.Name )
End Sub
Class clsSelect
    Private WithEvents oInteractEvents As InteractionEvents
    Private WithEvents oSelectEvents As SelectEvents
    Private bTooltipEnabled As Boolean
    Private ThisApplication As Inventor.Application
    Public SelectedOcc As ComponentOccurrence
    Private stillSelecting As Boolean = True
    Public Sub SelectOccurrence(oApp As Inventor.Application)
        ThisApplication = oApp
        oInteractEvents = ThisApplication.CommandManager.CreateInteractionEvents
        oInteractEvents.InteractionDisabled = False
        oSelectEvents = oInteractEvents.SelectEvents
        oSelectEvents.AddSelectionFilter(SelectionFilterEnum.kDrawingCurveSegmentFilter)
        oSelectEvents.WindowSelectEnabled = False
        bTooltipEnabled = ThisApplication.GeneralOptions.ShowCommandPromptTooltips
        ThisApplication.GeneralOptions.ShowCommandPromptTooltips = True
        oInteractEvents.StatusBarText = "Select component"
        oInteractEvents.Start()
        While stillSelecting
            ThisApplication.UserInterfaceManager.DoEvents()
        End While
    End Sub
    Private Sub oInteractEvents_OnTerminate() Handles oInteractEvents.OnTerminate
        ThisApplication.GeneralOptions.ShowCommandPromptTooltips = bTooltipEnabled
        oSelectEvents = Nothing
        oInteractEvents = Nothing
        stillSelecting = False
    End Sub
    Private Sub oSelectEvents_OnPreselect(ByRef PreSelectEntity As Object, ByRef DoHighlight As Boolean, ByRef MorePreSelectEntities As ObjectCollection, ByVal SelectionDevice As SelectionDeviceEnum, ByVal ModelPosition As Point, ByVal ViewPosition As Inventor.Point2d, ByVal View As Inventor.View) Handles oSelectEvents.OnPreselect
        Try
            Dim oCurves As DrawingCurvesEnumerator = DirectCast(PreSelectEntity, DrawingCurveSegment).Parent.Parent.DrawingCurves(DirectCast(PreSelectEntity, DrawingCurveSegment).Parent.ModelGeometry.Parent.Parent)
            Dim oCol As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
            For Each oCurve As DrawingCurve In oCurves
                For Each oSeg As DrawingCurveSegment In oCurve.Segments
                    If oSeg IsNot PreSelectEntity Then oCol.Add(oSeg)
                Next
            Next
            MorePreSelectEntities = oCol
            DoHighlight = True
        Catch
            DoHighlight = False
        End Try
    End Sub
    Private Sub oSelectEvents_OnSelect(ByVal EntireSelectedEntities As ObjectsEnumerator, ByVal SelectionDevice As SelectionDeviceEnum, ByVal ModelPosition As Point, ByVal ViewPosition As Point2d, ByVal View As Inventor.View) Handles oSelectEvents.OnSelect
        SelectedOcc = DirectCast(EntireSelectedEntities.Item(1), DrawingCurveSegment).Parent.ModelGeometry.Parent.Parent
        ThisApplication.CommandManager.StopActiveCommand
    End Sub
End Class
Replies (8)
A.Acheson
Hi @anavazquez5LRNJ
Once you have the occurrence just get the ParentOccurrence which is the sub assembly. Hopefully that answers your question.
Dim parentOccName as String  = oOcc.ParentOccurrence.Name
Regards
Alan
anavazquez5LRNJ
Hi @A.Acheson,Is it possible to select more than one occurrence, to be able to size n number of occurrences, since I can only size one occurrence each time the rule is executed, by the way thank you very much.
A.Acheson
It looks like your manually choosing the occurrences. Would it be easier to just get all occurrences in the view into a list and then just loop through the occurrence list? The function below is getting the views curves and returning one but it could be made into a sub routine and a list could be added.  Of course you could do the same with the occurrence selection tool you have and manually add the occurrence to the list leaving the user in control.
Function GetOccurrence(occName As String, curves As DrawingCurvesEnumerator) As ComponentOccurrence
	For Each curve As DrawingCurve In curves
		For Each curveSegment As DrawingCurveSegment In curve.Segments
			Try
				Dim modelGeom As Object = curve.ModelGeometry
				occ = modelGeom.ContainingOccurrence
			Catch
			End Try
			If occ.Name = occName Then
				Logger.Info("found occ from curve " & occ.Name)
				Return occ
			End If
		Next
	Next
End Function
Regards
Alan
anavazquez5LRNJ
Hi @A.Acheson, yes, I select occurrence by occurrence, I will try to test it as you suggest, one question, is it possible to set a dimension instead of me manually entering the coordinates in the code so to speak to place them where I need with a second click?
A.Acheson
In my opinion setting up a generic spacing would be a good start and then you can use the arrange command which can do a good job of avoiding geometry etc. There is sample for picking up the mouse location on the forum but I would think this would be difficult but by all means. Here is a post for mouseclick position
Regards
Alan
anavazquez5LRNJ
You are right I have been trying to implement this code in mine and I have not succeeded, it works if I separate the rules but when I want to put them together so to speak it does nothing.
A.Acheson
Well it sounds like your progressing so. Some more logger statements are needed so to see what stage the hangup is occurring at. My preference would be to just launch the rule on the whole view with no user interaction. Can you attach the code and some error messages (more info tab) and an indication of where it is failing?
Regards
Alan
anavazquez5LRNJ
Hi @A.Acheson ,I no longer see errors as such but I have some problems with the rule, for example the rule does not always work, if the cursor is not positioned on the sheet or if you touch the view with the cursor or simply stops working and no longer lets you select the component, I do not know if this is because of the class that selects the components or is something wrong declared, because I need to let me choose any part of the sheet so that there is placed the dimension of the occurrence.
