select the export parameter box in fx parameters using iLogic
JasonMayes
JasonMayes
I am trying to find a way to check the "export parameter" checkbox on in "fx parameters" using iLogic to add to exsiting rule. Any help would be greatly appreciated.
Jason Mayes
WCrihfield
Hi @JasonMayes.  That is a property of the Parameter API object called ExposedAsProperty, which has a Read/Write Boolean type value.  There are lots of examples of how to access and change that property here on this forum.
Dim oParams As Inventor.Parameters = ThisDoc.Document.ComponentDefinition.Parameters
Dim oParam As Inventor.Parameter = oParams.Item(1)
'this next line will 'toggle' that setting every time you run it
oParam.ExposedAsProperty = Not oParam.ExposedAsProperty
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
(Not an Autodesk Employee)
JasonMayes
