Hi @JasonMayes. That is a property of the Parameter API object called ExposedAsProperty, which has a Read/Write Boolean type value. There are lots of examples of how to access and change that property here on this forum.
Dim oParams As Inventor.Parameters = ThisDoc.Document.ComponentDefinition.Parameters
Dim oParam As Inventor.Parameter = oParams.Item(1)
'this next line will 'toggle' that setting every time you run it
oParam.ExposedAsProperty = Not oParam.ExposedAsProperty
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS)
Wesley Crihfield
(Not an Autodesk Employee)
