Select set problem
Select set problem
Select set problem
This code works in a main assembly but it doesnt work if the sketch is in a subassembly. I think it is about selecting parts in context of a assembly. Here is the picture of the situation where the rule is used. Any help please?
Dim oDoc As Document
oDoc = ThisApplication.ActiveDocument
Dim oObject As Object
oObject = ThisApplication.ActiveEditObject
Dim oSelectSet As SelectSet
oSelectSet = oDoc.SelectSet
If oObject.Type = ObjectTypeEnum.kPlanarSketchObject Then
	For Each oEntity In oObject.SketchEntities
		If oEntity.ConstraintStatus = 51716 Or oEntity.ConstraintStatus = 51715 Then
			'kUnknownConstraintStatus
			'kOverConstrainedConstraintStatus
			oSelectSet.Select(oEntity)
	Next
	If oEntity.Type = 83896576 Then
		'kSketchPointObject
		If oEntity.Reference = True Then
	Next
Martin-Winkler-Consulting
You are in edit mode of the sketch or/and the included Part.
Have a look wether the select object of the main assembly have members within this status.
Try selecting the sketch without edit mode.
Martin Winkler
CAD Developer
Did you find this post helpful? Feel free to like this post.
JhoelForshav
Hi @Anonymous
It's a bit complex to do it this way since you want to access the sketch from the top assembly. You'll have to create a proxy object of the sketch in the top assembly in order to select entities from it with the top assemblys select set.
I wrote this for you. Hope it helps 🙂
Sub Main
Dim oDoc As AssemblyDocument
	Dim oSketchProx As Object = CreateSketchProxy(oDoc.ComponentDefinition.ActiveOccurrence.OccurrencePath, oObject.Name)
	For Each oEntity In oSketchProx.SketchEntities
	Next
	If oEntity.Type = 83896576 Or oEntity.Type = kSketchPointProxyObject Then 'Its now a sketchpointproxy
		'kSketchPointObject
	Next
End Sub
Function CreateSketchProxy(oOccList As ComponentOccurrencesEnumerator, oSketchName As String) As Object
	Dim oProx As Object
	For i = oOccList.Count To 1 Step -1
		If i = oOccList.Count
			Call oOccList(i).CreateGeometryProxy(oOccList(i).Definition.Sketches.Item(oSketchName), oProx)
		Else
			Call oOccList(i).CreateGeometryProxy(oProx, oProx)
	Next
	Return oProx
End Function
Ok this is the solution but this is one complex code.....
JhoelForshav
Yes, working with objects within occurrences from the containing assembly can be a bit complex since you have to set up a proxy for them. The assembly itself contains only a structure with references to other parts/assemblies. Therefore these objects doesn't really exist within the assembly so you have to create proxies to reference them.
In the UI this is done automatically when you select the objects.
The function I've written here (CreateSketchProxy) might look a bit complex, but it's written that way in order to be able to dig up proxies from all levels. The rest of the code is basically the same as the one you posted to begin with 🙂
I always struggle with using proxies, I read abou them (https://adndevblog.typepad.com/manufacturing/2013/07/occurrences-contexts-definitions-proxies.html)
but i just don't understand how to use them in situaions like this one. A lot of my questions on the forum are about using proxies.
Anyway, here is the rest of my code in VBA. I will use it to clear sketshes of broken geometry enteties.
Sub ClearSketch_CLEAR()
Set oDoc = ThisApplication.ActiveDocument
Set oObject = ThisApplication.ActiveEditObject
Set oSelectSet = oDoc.SelectSet
    If oDoc.FullDocumentName = oObject.Parent.Document.FullDocumentName Then
        Set oSketchProx = ThisApplication.ActiveEditObject
    Else
        Set oSketchProx = CreateSketchProxy(oDoc.ComponentDefinition.ActiveOccurrence.OccurrencePath, oObject.Name)
    For Each oentity In oSketchProx.SketchEntities
        If oentity.ConstraintStatus = 51716 Or oentity.ConstraintStatus = 51715 Then
            oSelectSet.Select (oentity)
    Next
    If oentity.Type = 83896576 Or oentity.Type = kSketchPointProxyObject Then 'Its now a sketchpointproxy
        'kSketchPointObject
        If oentity.Reference = True Then
    Next
    ThisApplication.CommandManager.ControlDefinitions.Item("BreakLinkCmd").Execute2 (True)
    ThisApplication.ActiveDocument.Update
End Sub
    Dim oProx As Object
        If i = oOccList.Count Then
        Else
    Next
    Set CreateSketchProxy = oProx
End Function
JhoelForshav
I get that. I actually did my masters thesis on the subject of building product configurators in Inventor. The use of proxies in assembly constraints etc. drove me crazy back then😅
Thanks for sharing the complete code! Im sure it'll come in handy for a lot of people here! 🙂
