Select case = or less than in ilogic
Hi guys,
With the help here, I had a great result with my plates format yesterday and now I am trying to do the same with round bars but alittle bit trickier because I need to add less or equal to or greater than.
so I want it to say that if my roundbar is less than or equal to .25 then use 446-1004 but I cant get it to work.
then for the second line is >= .3125 and so on
Thanks again in advance!
iProperties.Value("Custom", "Thickness") = B_DIA
oThickness = iProperties.Value("Custom", "Thickness")
odrawingname = ThisDoc.FileName(False)
namedxf = Left(odrawingname,3) & "\" & Mid(odrawingname, 5,8)
ofilename = namedxf & ".DXF"
iProperties.Value("Project", "Description") = "=RNDBAR,4140 HTSR, <B_DIA> DIA"
iProperties.Value("Project", "Cost Center") = "=<B_L>"
iProperties.Value("Summary", "Keywords") = "BP#" & ofilename
'select the case for B_DIA
Select Case B_DIA
    Case >= 0.25
        oSN = "446-1004"
    Case 0.3125
        oSN = "446-1005"
    Case 0.375
        oSN = "446-1006"
   Case Else
        oSN = "446-????"
End Select
iProperties.Value("Project", "Stock Number") = oSN
I've got it to work when I did Case is < 1... hmmmm..but I want something if its less than..
rikard.nilsson
You write "less than or equal to .25" but the Case says "Case >= 0.25"..
But I try to give you some example
If you move it to last. Then your example works..
Dim B_DIA = 0.3
Select Case B_DIA
    Case 0.3
        MessageBox.Show("0,3", "Title")
    Case 0.4
        MessageBox.Show("0,4", "Title")
    Case >= 0.25
        MessageBox.Show("0,25", "Title")
   Case Else
       MessageBox.Show("< 0,25", "Title")
End Select
If you want to set limitation to the Case, then this works..
Dim B_DIA = 0.4
Select Case B_DIA
    Case <= 0.25
    Case 0.25 To 0.399999999
        MessageBox.Show("0,25 to max 0,39999", "Title")
    Case >= 0.4
        MessageBox.Show(" >= 0,4", "Title")
   Case Else
End Select
Maybe this will help you..
/Rikard
ekinsb
Using a "Select Case" won't work as expected in this case because of an issue when comparing floating point numbers.  You can read more about it here.  The code below however will do the comparisons correctly but still won't do what you want because if the value is greater than 0.25 the first If statement will be run and the others will never be evaluated.  If it's less than 0.25 then the last Else If will be executed so you need to make sure the evaluations happen in the correct order.  I'm not sure what the rules are in your case so I didn't change anything but a check for a range of values (anything greater than 0.25 in this case) should take place after the checks for specific values.
If B_DIA >= 0.25 Then
    oSN = "446-1004"
Else If Math.Abs(B_Dia - 0.3125) < 0.00000001 Then
    oSN = "446-1005"
Else If Math.Abs(B_Dia - 0.375) < 0.00000001 Then
    oSN = "446-1006"
Else
    oSN = "446-????"
It would be simpler to use the tolerance function that's described in the link above but I wrote this code so it's not dependent on any other functions.  The main thing to remember is that you shouldn't ever directly compare two floating numbers for equivalency but instead need to check that they're the same within some tolerance.
Brian Ekins
Mod the Machine blog
Thanks for clearing that up.. Will test this out in a bit!!
Owner2229
This should work for the floating point number issue as well:
Select Case Math.Round(B_DIA, 0.000001)
    Case <= 0.25: oSN = "446-1004"
    Case 0.3125:  oSN = "446-1005"
    Case 0.375:   oSN = "446-1006"
    Case Else:    oSN = "446-????"
End Select
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
