Section View Label in Base View (Not require symbol to complete)
Tiffany_Hayden_
Tiffany_Hayden_
Hi I've been researching to find a solution but all solutions required adding a symbol to the library (Template). Is there a solution that just lets you edit this feature? (See picture below) I've looked into the formattedtext property and I thought that might be the solution but it seems to edit both fields. sectionviews.png
Tiffany Hayden
NachitoMax
i am trying to do the same thing as you. unfortunately that label & the detail view label are not exposed to the api. You can manually edit them and delete the text but not by code im afraid
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
A.Acheson
@Jim_O @jacob.dillingham
I just wanted to draw your attention to this post. It will most likely  help someone. It sounds like the bulk of the work is complete. I have yet to implement and test.
https://forums.autodesk.com/t5/inventor-forum/is-there-a-child-complement-to-lt-parent-sheet-index-g...
Regards
Alan
Tiffany_Hayden_
Thank you @A.Acheson I'll take a look!
Tiffany
Tiffany Hayden
