Search Header Directory and all Sub Directories for a File.
C_Haines_ENG
C_Haines_ENG
I am looking to create a search program that will go through a rather large folder heiarchy and find a specific file. This way I can print, open, copy, etc without having to remember exactly where a file is stored.
Ive seen code HERE that searches through a single directory, but I was hoping there would be a more efficient way of doing this without "For" looping every sub directory.
dalton98
you need to change the search option. ex:
Dim fi As System.IO.FileInfo() = FileLocation.GetFiles("*" & partOfName & "*", IO.SearchOption.AllDirectories)
Dev_rim
Hi there,
You can search for some file in all sub directories too:
Dim filePaths As String() = Directory.GetFiles(YOUR_HEADER_FOLDER_PATH, YOUR_FILTER, SearchOption.AllDirectories)
The importing thing is the use System.IO.Directory class and add the third parameter SearchOption.AllDirectories
YOUR_HEADER_FOLDER_PATH should be your header folders path. Lets say I want to get every file on public desktop. Then its = "C:\Users\Public\Desktop"
And I want to get all the files contain "TEST" on their name. Then Filter will be "*TEST*".
so at the end this is the final:
Dim filePaths As String() = Directory.GetFiles("C:\Users\Public\Desktop", "*TEST*", SearchOption.AllDirectories)
For example if you want to get all Part Document files in C disk, you can use:
Dim filePaths As String() = Directory.GetFiles("C:\", "*.ipt", SearchOption.AllDirectories)
You can use Wildcards on filter. Further information about the wildcards:
https://learn.microsoft.com/en-us/office/vba/language/reference/user-interface-help/wildcard-charact...
I hope it helps.
If my answer is solved your problem, please mark it as Solution
Freundliche Grüße / Kind Regards
C_Haines_ENG
Thank you!
WCrihfield
Hi @C_Haines_ENG.  I don't know how you are planning on using this method for (in simple iLogic rule, VBA macro, Add-In, EXE, or other), but keep in mind that the GetFiles method and EnumerateFiles methods are similar, but act differently, and it may pay off to know the difference, and use the one that is most appropriate to your situation.  When using the GetFiles method, it must completely build out its entire contents before allowing you to start iterating through its contents, which can be unnecessarily slower in certain situations, but be the appropriate one to use in other situations.  When using the EnumerateFiles method, it will allow the iteration of its contents immediately, before it has finished building the list out, which can allow the process to finish sooner in some situations.  Both have their pros & cons, and you can read more about them online if needed.  Just putting that stuff out there as food for thought.
Wesley Crihfield
(Not an Autodesk Employee)
