Search and Replace Rule Text from Other Rule
Dear all,
Is there a rule to change text in other rule?
Example:
If Parameter ("ANG_LEFT") > 89 And Parameter ("ANG_LEFT") < 91 Then
Feature.IsActive("HOLE_ONE")= True
Feature.IsActive("HOLE_TWO")= False
End If
Nothing wrong so far. But this rule is in 100 parts. And 91 has to be 92.
Now i want use "Code Injector" to place the "search and replace rule". But I don't know how to change text from other rule.
b_sharanraj
In code Injector we have two options to do this,
Option 1
If the Rule Name is same in all the 100 Parts, then use "Overwrite Duplicate Rules" from Advanced Options
Option 2
If the Rule Name are not same in all the 100 Parts, then use "Delete all Rules" and add New Rule using "Keep Rule after Run" from Advanced Options.
Regards
B.Sharan Raj
Dear B. Sharan Raj,
This could be a solution. Because the Rule Name (and the "If Parameter..." Also) is always the same but the feature names differ almost every time.
That's why, I think, I have to address the specific Numbers.
I have a rule to get the text of a Rule (But it will search Random, not on given name in Rulelist)
SyntaxEditor Code Snippet
Dim oList As Collection = New Collection
oattributes = ThisDoc.Document.attributesets.item("iLogicRule_Name6")
For Each oattribute In oattributes
oList.Add(oattribute.Value.tostring())
Next
If oList.Count = 0 Then
MessageBox.Show("Empty", "ParameterList")
Return
Else
For Each st In oList
sTotal = sTotal + st & vbNewLine
Next
End If
MessageBox.Show(sTotal,"AttributeList")
And I have a Rule to Search and replace Parameters
'Name of Rule: Search_and_Replace_Parameter
oSearch = InputBox("Search", "Search_and_Replace", "Find what")
oReplace = InputBox("Replace", "Search_and_Replace", "Replace with")
For Each oParameter In ThisApplication.ActiveDocument.ComponentDefinition.Parameters
'Returns index where found, or -1 if not found
If oParameter.Name.IndexOf(oSearch) > -1 Then
oParameter.Name = oParameter.Name.Replace(oSearch, oReplace)
End If
Next
So I need to combine these two and a need a way that it searches for a specific name
I'm almost there, this works in single part:
'Name of Rule: Search_and_Replace_iLogic
If iLogicVb.Automation.GetRule(ThisDoc.Document, "Different Angle").text.IndexOf(oSearch) > -1 Then
iLogicVb.Automation.GetRule(ThisDoc.Document, "Different Angle").text = iLogicVb.Automation.GetRule(ThisDoc.Document, "Different Angle").text.Replace(oSearch, oReplace)
End If
Now I only have to make it usable for Code Injector
FOUND IT!
'To Change
oRule = "Different Angle"
oSearch = "83.5"
oReplace = "83"
If iLogicVb.Automation.GetRule(ThisDoc.Document, oRule).text.IndexOf(oSearch) > -1 Then
iLogicVb.Automation.GetRule(ThisDoc.Document, oRule).text = iLogicVb.Automation.GetRule(ThisDoc.Document, oRule).text.Replace(oSearch, oReplace)
End If
