- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am trying to make a rule that lets me select parts in an assembly and then generate .stp files of chosen parts, and then save them into vault.
I am using Inventor Professional 2023 and Vault Professional 2023.
I have this rule below, that lets me choose parts and then generates .stp files of those parts into a chosen folder, but i dont know how to make it to save those stp files to vault.
Is there a way to save those files directly to vault?
Or a way to automaticly import them into vault after saving them into a folder on my desktop?
Here is the rule:
Sub Main() Dim ass As AssemblyDocument = ThisApplication.ActiveDocument Dim oSelSet As SelectSet = ass.SelectSet If oSelSet.Count = 0 Then MessageBox.Show("Proszę wybrać pliki przed uruchomieniem polecenia", "Error") Exit Sub End If 'this runs the custom Function defined below to return a selected folder path oFolder = GetFolder 'make sure a folder was selected, if not exit rule If String.IsNullOrEmpty(oFolder) Then Exit Sub Dim i As Integer = 0 Dim result As Boolean Dim Occ As ComponentOccurrence For Each Occ In oSelSet Dim OccDoc As Document = Occ.Definition.Document 'get file name (without path & without file extension) oName = System.IO.Path.GetFileNameWithoutExtension(OccDoc.FullFileName) 'put new STEP file name together oNewName = oFolder & "\" & oName & ".stp" result = ExportToSTEP(OccDoc, oNewName) If result = True Then i = i + 1 End If Next MessageBox.Show("Liczba zapisanych plików: " & i, "Wynik zapisu") End Sub 'Here's the subroutine. Function ExportToSTEP(doc As Document, NewFileName As String) As Boolean ' Get the STEP translator Add-In. Dim oSTEPTranslator As TranslatorAddIn oSTEPTranslator = ThisApplication.ApplicationAddIns.ItemById("{90AF7F40-0C01-11D5-8E83-0010B541CD80}") If oSTEPTranslator Is Nothing Then MsgBox("Could not access STEP translator.") ExportToSTEP = False Exit Function End If oContext = ThisApplication.TransientObjects.CreateTranslationContext oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism oOptions = ThisApplication.TransientObjects.CreateNameValueMap oData = ThisApplication.TransientObjects.CreateDataMedium oData.FileName = NewFileName If oSTEPTranslator.HasSaveCopyAsOptions(doc, oContext, oOptions) Then ' Set application protocol. ' 2 = AP 203 - Configuration Controlled Design ' 3 = AP 214 - Automotive Design oOptions.Value("ApplicationProtocolType") = 3 'oOptions.Value("Author") = "" 'oOptions.Value("Authorization") = "" 'oOptions.Value("Description") = "" 'oOptions.Value("Organization") = "" oSTEPTranslator.SaveCopyAs(doc, oContext, oOptions, oData) ExportToSTEP = True End If End Function Function GetFolder() As String 'Imports System.Windows.Forms Dim oSFolder As String Dim oFDialog As New System.Windows.Forms.FolderBrowserDialog oFDialog.Description = "Wybierz folder do zapisu plików .step." oFDialog.RootFolder = System.Environment.SpecialFolder.MyComputer Dim oResult As DialogResult = oFDialog.ShowDialog() If oResult = DialogResult.OK Then oSFolder = oFDialog.SelectedPath Else Return String.Empty End If Return oSFolder End Function
