02:43 AM
- Mute
- Permalink
- Report
Hello
I have been exporting as STEP using the code supplied from the snippets.
My question is where in the code does it assign the save location? Can I send the STEP file out to a shared network location as an alternative to the default original folder?
Any help will be greatly appreciated.
' Get the STEP translator Add-In.
Dim oSTEPTranslator As TranslatorAddIn
oSTEPTranslator = ThisApplication.ApplicationAddIns.ItemById("{90AF7F40-0C01-11D5-8E83-0010B541CD80}")
Dim oContext As TranslationContext
oContext = ThisApplication.TransientObjects.CreateTranslationContext
Dim oOptions As NameValueMap
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
If oSTEPTranslator.HasSaveCopyAsOptions(ThisApplication.ActiveDocument, oContext, oOptions) Then
' Set application protocol.
' 2 = AP 203 - Configuration Controlled Design
' 3 = AP 214 - Automotive Design
oOptions.Value("ApplicationProtocolType") = 3
' Other options...
'oOptions.Value("Author") = ""
'oOptions.Value("Authorization") = ""
oOptions.Value("Description") = iProperties.Value("Summary", "Title")
oOptions.Value("Organization") = "© XXXX XXXXX XXXXX " & Now.ToString("yyyy")
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
Dim oData As DataMedium
oData = ThisApplication.TransientObjects.CreateDataMedium
oData.FileName = ThisDoc.PathAndFileName(False) & "_" & iProperties.Value("Project", "Revision Number")& ".stp"
oSTEPTranslator.SaveCopyAs(ThisApplication.ActiveDocument, oContext, oOptions, oData)
End If
