Run external rule
madstrolle
Run external rule
madstrolle
I get this error when trying to run external rules, with a macro.
But if I run the rule directly from ilogic browser it works fine and after I had run it from the browser it also works through the macro.
Has anyone experienced the same problem?
WCrihfield
Hi @madstrolle.  Have you set up your iLogic Configuration settings yet.  When you call an iLogic rule to run indirectly, Inventor will first look within the folders you have specified within your iLogic configuration settings to find that text file's location, so it can run it.  And if the file extension does not match the current setting, it might not work correctly either.
Wesley Crihfield
(Not an Autodesk Employee)
madstrolle
@WCrihfield Thanks!
So simple🙃
