Run a Vba Macro after Save Document
Hello, fellows,
My issue this time is:
How can I run a VBA macro after Save my Opened Document?
I mean, How can I run a VBA macro when I'm saving an Opened Document?
Thanks!
bjweix
The auto VBA macros are deprecated, you can use iLogic event trigger instead.
dano0310
As mentioned above use an event trigger to run an iLogic rule which then runs a macro.
InventorVb.RunMacro("ApplicationProject", ModuleName, MacroName)
 The first item doesn't necessarily have to be the application project if the macro is within the part.
Regards Dan
Ok! I got there.
I have many files, so I need a way to run the rule
with the event trigger "Run this rule - After Save Document" automatically, with no need to do the same task to each file. I say this also because of the other users of our net, that they don't need to remember the task.
I would like to get the Event Trigger automatically too.
smilinger
Try search "Code Injector" in the forum, which can be used to set event triggers for lots of files in batch.
adam.nagy
Autodesk Support
Autodesk Support
In the long term it can be a real problem keeping track of which document is running what code and modify any of them if necessary - e.g. to change the logic in it. The best would be to go with addin's as pointed out here:
http://modthemachine.typepad.com/my_weblog/2008/09/vba-document-projects.html
Cheers,
Adam Nagy
Autodesk Platform Services
