Run a external rule when a user parameter is changed?
S_Verbeek
S_Verbeek
is ther a way to run a external rule when a user parameter is changed?
In the event trigger it is only possible with model parameter but not with user parameters.
Best regards
Stefan
__________________________________________________________________________________
Stefan Verbeek
Mitarbeiter Support bei
bradeneuropeArthur
Arthur Knoors
Autodesk Affiliations:
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
