Hi @david_lowndes,
I think I use a slightly different method to you, and it's spliced from other rules we currently use so it may be a little longer than necesssary, but I use this to open all existing drawings of parts within an assembly.
'For mass updating small changes to part/assembly details to their respective Drawings.
Sub main '[
'Create a List of all Componenets
Dim ComponentMap As NameValueMap = CreateComponentMap()
'Check for zero result, run updater
If Not ComponentMap Is Nothing Then
'Check Assembly for files without a drawing
Dim nonIDW As Integer = CheckAssemblyIDW(ComponentMap)
UpdaterGo(ComponentMap, nonIDW)
End If
End Sub ']
Sub UpdaterGo(vMap As NameValueMap, nonIDW As Integer)
CreateProgressBar("Opening IDWs...", "Opened: ", (vMap.Count-nonIDW))
Dim i As Integer
Dim vDoc As Document
For i = 1 To vMap.Count
Dim vFullFileName As String = vMap.Name(i)
If CheckForFileIDW(vFullFileName) = True Then
Dim idwPathName As String = Left(vFullFileName, Len(vFullFileName) -3) & "idw"
vDoc = ThisApplication.Documents.Open(idwPathName, True)
System.Threading.Thread.CurrentThread.Sleep(1000)
IncrementProgressBar(1)
End If
Next
ThisProgressBar.Close
MessageBox.Show("All Drawings Opened.", "Update Complete", MessageBoxButtons.OK, MessageBoxIcon.Information)
End Sub
'Check each file for a corresponding idw
Function CheckForFileIDW(FileName As String)
Dim State As Boolean = True
Dim idwPathName As String = Left(FileName, Len(FileName) -3) & "idw"
If (System.IO.File.Exists(idwPathName)) = 0 Then
State = False
Return State
Else
Return State
End If
End Function
'Uses BOM iLogic Rule to produce Component List
Function CreateComponentMap() As NameValueMap
'Initialise Arguments
Dim oRuleArguments As NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap()
'find Project Folder Location in preparation to call external rule
Dim IPJ As String
Dim IPJ_Name As String
Dim IPJ_Path As String
Dim FNamePos As Long
'set a reference to the FileLocations object.
IPJ = ThisApplication.FileLocations.FileLocationsFile
'get the location of the last backslash seperator
FNamePos = InStrRev(IPJ, "\", -1)
'get the project file name with the file extension
IPJ_Name = Right(IPJ, Len(IPJ) - FNamePos)
'get the path of the folder containing the project file
IPJ_Folder_Location = Left(IPJ, Len(IPJ) -Len(IPJ_Name))
'Call External Rule
iLogicVb.RunExternalRule(IPJ_Folder_Location & "iLogic Scripts\BOM", oRuleArguments)
'Retreive Result
Dim Result As NameValueMap
Try
Result = CType(oRuleArguments.Item("BOM"), NameValueMap)
Catch
Result = Nothing
End Try
Return Result
End Function
'Cycle through all unique assembly parts to check for an idw
Function CheckAssemblyIDW(oList As NameValueMap)
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
Dim i As Integer = 1
Dim k As Integer = 1
'Dim txtFileName As String = ThisDoc.PathAndFileName(True) & " No IDWs.txt"
'oMsg = System.IO.File.CreateText(txtFileName)
' oMsg.WriteLine("Parts and Assemblies with No IDW file:")
'oMsg.WriteLine("")
For i = 1 To oList.Count
Dim vFullFileName As String = oList.Name(i)
'List parts/assemblies without an idw two to a line
'oMsg.WriteLine(k & ". " & Right(vFullFileName, Len(vFullFileName) -InStrRev(vFullFileName, "\")) & " ")
k = k + 1
End If
Next
'oMsg.Close
'ThisDoc.Launch(txtFileName)
Return k - 1
End Function
Dim ThisProgressBar As Inventor.ProgressBar
Dim ThisProgressBarMessage As String
Dim ThisProgressBarTotal As Integer
Dim ThisProgressBarCount As Integer
Sub CreateProgressBar(Title As String, Message As String, Total As Integer)
ThisProgressBar = ThisApplication.CreateProgressBar(False, Total, Title)
ThisProgressBarMessage = Message
ThisProgressBarTotal = Total
ThisProgressBarCount = 0
ProgressBarDisplay()
End Sub
Sub IncrementProgressBar(Change As Integer)
ThisProgressBarCount = ThisProgressBarCount + Change
End Sub
Sub ProgressBarDisplay()
ThisProgressBar.Message = ThisProgressBarMessage & ThisProgressBarCount & "/" & ThisProgressBarTotal
ThisProgressBar.UpdateProgress()
End Sub
