Rotate sketchblock
taher.basha
Rotate sketchblock
taher.basha
I want to rotate a sketch block using vb.net or C#
It's just to read the current position and rotate to some angle
Replies (9)
taher.basha
I have tried this but is there any other method as well?
Michael.Navara
taher.basha
I want to basically
1. Insert(from other sketch),
2. rotate and
3. position a block as per user inputs of X and Y value.
I could be able to insert and  rotate it with the solution you posted above but I couldn't be able to position it since the sketchblock coordinates reading the insertion position which is offset from origin. After rotation I want to modify sketchblock coordinates to x=0,y=0
Michael.Navara
Can you share your code? May be this can be fixed easily.
J.Pelfrene
I did something like this before:
Public Sub Main()
	Dim oPartDoc As PartDocument = ThisApplication.ActiveDocument
	Dim oSketch As PlanarSketch = oPartDoc.ComponentDefinition.Sketches.Item(1)
	If Not oPartDoc.SketchActive Then oSketch.Edit
	Dim oSketchObjects As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
	For Each oEnt In oSketch.SketchBlocks
		oSketchObjects.Add(oEnt)
	Next
	Dim oCen As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(0,0)
	oSketch.RotateSketchObjects(oSketchObjects, oCen, Math.PI/2, False, True)
	Dim allMinPoints As List(Of Point2d) = oSketch.SketchEntities.Cast(Of SketchEntity).Select(Function(e) e.RangeBox.MinPoint).OrderBy(Function(p) p.X).ToList()
	Dim minX = allMinPoints.First().X
	Dim minY = allMinPoints.OrderBy(Function(p) p.Y).First().Y
	Dim oVec As Vector2d = ThisApplication.TransientGeometry.CreateVector2d(-minX/2,-minY/2)
	oSketch.MoveSketchObjects(oSketchObjects, oVec)
End Sub
Angle is set to 90° counterclockwise (Math.PI/2). Change this for the angle you need.
I still don't really understand why it is necessary to add the factor 1/2 for the vector coordinates, but that way seems to work well for positioning the sketch neatly in the 1st quadrant.
taher.basha
TransientGeometry tg = invApp.TransientGeometry;
Matrix2d mx = tg.CreateMatrix2d();
//mx= skb[cbLetters.SelectedIndex].Transformation;
double x = Convert.ToDouble(txtBoxXDir.Text)/10;
double y = Convert.ToDouble(txtBoxYDir.Text)/10;
double angle = Convert.ToDouble(txtBoxAngle.Text);
double oRad = (angle / 180) * 3.14159265358979;
mx.SetToRotation(oRad, tg.CreatePoint2d(0, 0));
skb[cbLetters.SelectedIndex].Transformation=mx;
mx.SetTranslation(tg.CreateVector2d(x, y));
invApp.ActiveDocument.Update();
taher.basha
I did almost the same with below code
but can i get some reference for Matrix and transformation
taher.basha
I did somthing like this
static void Rotate(SketchBlock sketchBlock)
    TransientGeometry tg = InvAccess.InvApp.TransientGeometry;
    Matrix2d mx1 = tg.CreateMatrix2d();
    mx1= sketchBlock.Transformation.Copy();
    double oRad = Math.PI/2;
    Matrix2d mx2 = tg.CreateMatrix2d();
    mx2.SetToRotation(oRad, tg.CreatePoint2d(0, 0));
    mx1.PreMultiplyBy(mx2);
    sketchBlock.Transformation=mx1;
    PartAccess.Model.prtDoc.Update();
which is luckly working.
and I will again explain the scenario. I have a block say A which is vertical at the center and I want to rotate it to 90deg and move it to y=somevalue(say 20)
