Right Click Menu
NachitoMax
Right Click Menu
NachitoMax
Hi
Is it possible to add a custom menu line on the Right Click menu of a drawing view? I would like to add a button where the red line currently is (or somewhere in that region)
Nacho
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
bradeneuropeArthur
with this piece of code:
Public Sub AddButtonToRightMouseButton(oButton As Inventor.ButtonDefinition, oCommandBar As Inventor.CommandBar)
        Try
            'MsgBox(oCommandBar.Controls.Item(1).DisplayName)
            ' Check if the context menu has the 'Home View' (formerly 'Isometric View') command
            Dim oCmdBarControl As CommandBarControl
            oCmdBarControl = oCommandBar.Controls.Item("AppIsometricViewCmd")
            Dim ControlsCounter As Integer
            ControlsCounter = oCommandBar.Controls.Count
            If Not oCmdBarControl Is Nothing Then
                ' Add the button command before the home view command
                'Call CommandBar.Controls.AddButton(m_largeButtonDataCard, oCmdBarControl.Index)
                ' add the buttonCommand to the end
                Call oCommandBar.Controls.AddButton(oButton, ControlsCounter)
            End If
        Catch ex As Exception
        End Try
    End Sub
 To provide you the complete add in I need some more time.
  • Regarding the Buttons
  • and the commandbars
let me know if this is sufficient for the moment?
Arthur Knoors
Autodesk Affiliations:
