Revision Cell & Derived Parameter
I am having some issues trying to set a parameter to Included from a derived part.   The following runs without error, and I can put a watch on oDerivedPartDef.Definition.Parameters.Item("Plate_6_Thk").IncludeEntity, and it never changes from False to True.  What am I missing?
Also Is there no way to change a Revision Cell to or from Static?
Public Sub Derived()
Dim oDoc As PartDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oDerivedPartDef As DerivedPartComponent
Set oDerivedPartDef = oDoc.ComponentDefinition.ReferenceComponents.DerivedPartComponents(1)
oDerivedPartDef.Definition.Parameters.Item("Plate_6_Thk").IncludeEntity = True
If Err Then Stop
End Sub
Jef_E
It's somthing really stupid.. you must set back the definition.. struggled with this also for a while :grinning_face_with_smiling_eyes:
oDoc.ComponentDefinition.ReferenceComponents.DerivedPartComponents(1).Definition = oDerivedPartDef
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
Thanks Jef,
I did have to change it a bit to get it to work, and I probably still don't have it quite right since it throws an error.  I will look into it more next time I need to do a bunch of files.   This is what I ended up with though.
Dim oDerivedPartDef As DerivedPartUniformScaleDef
Set oDerivedPartDef = oDoc.ComponentDefinition.ReferenceComponents.DerivedPartComponents(1).Definition
oDerivedPartDef.Parameters.Item("Plate_6_Thk").IncludeEntity = True
If Err Then Stop
