Resetting parameter value?
So a quick explanation to understand the context this question is in. I have a part that is split into 3 pieces with workplanes. These 3 pieces are derived from one part. In a larger assembly these 3 pieces are constrained back the same way.
The base component as explained above.
I expect questions asking me why I even made it this way. I did not make it this way but I've been tasked with making a product configuration for this larger assembly.
Each of these derived parts can only be a max of 2.9 m in length.
Derived middle part.
The thing that makes this assignement tricky is that I have to be able to freely alter the length but because of the restrictions on the maximum length of the derived part I'll have to add another middle part as seen above to the already existing three. This I plan to achieve by just using model states and have the rule switch between them depending on the total length. When the base component reaches the maximum length of let's say 7750 mm another middle part has to be added but the length has to be reset to to its starting value tp make up for the added part. My questions is if there is a way to reset a value. I already considered working with a min and max value by having the value equal the min or max once it crosses that border but that wouldn't solve the problem either. Another issue is that It would also need to keep aading up. So let's say it's at 7700 mm and I add another 100 mm, it would need to go to 6360 mm then. I'm mostly interested in knowing if there is a way to reset a value but thought I'd provide the context. Also this is just an idea, if anyone has a better one, shoot. Inventor 2022/Windows 10.
