Reset detail view identifier
GKR2023
GKR2023
Is there a way/code to reset the view identifier?
F.E. I have to copy design quite a few drawings. And when I have to work on them and delete some of the details. It will keep the View Identifier at the highest letter. And I would like it to reset at the first letter "A"
Ciao
bradeneuropeArthur
I had years ago already the same question part related.
https://forums.autodesk.com/t5/inventor-forum/reseting-counting-number-of-browser-node-name/m-p/1106...
Arthur Knoors
Autodesk Affiliations:
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
