Replace reference file for a specific drawing view.
Jef_E
Jef_E
I am trying to add a specific workflow into our Inventor but I am failing to do so.
 The situation
We draw pressure tanks and vessels, on these tanks there are many nozzles that are the same (components), but only vary in size.
Our workflow now is draw 1 nozzle and create a copy design, change the size and there is a new nozzle. We do this until the 3D model is finished.
Then we start to create detail drawings for these nozzles, which works quite fast, but.. (here is the problem) We copy the drawing view to another drawing, and then use change model reference to create the detail the next nozzle.
The problem
The copying to another drawing and then copying it back is too much work.. as we do this alot... So what I was attempting to is eliminating these steps.
I tried having the user select a drawing view, and then replacing the referenced file. But when I do this the reference for the other drawing view is also changed.. ughh bummer!
Here is my code ( quick code for testing) but how can I change the drawing view reference file for a specific drawing view?
        ' Get the active document
        Dim oDoc As DrawingDocument =
            _invApp.ActiveDocument
        ' Get the selected view
        Dim oDrawingView As DrawingView =
            oDoc.SelectSet.Item(1)
        ' Return the model reference
        Dim oReference As String
        oReference = oDrawingView.ReferencedDocumentDescriptor.ReferencedFileDescriptor.ReferencedFile.FullFileName
        ' Browse for a file
        Dim fd As OpenFileDialog = New OpenFileDialog()
        Dim strFileName As String
        fd.Title = "Open File Dialog"
        fd.InitialDirectory = IO.Path.GetDirectoryName(oReference)
        fd.Filter = "All files (*.*)|*.*|All files (*.*)|*.*"
        fd.FilterIndex = 2
        fd.RestoreDirectory = True
        If fd.ShowDialog() = DialogResult.OK Then
            strFileName = fd.FileName
        Else
            Exit Sub
        End If
        ' Replace the reference
        oDrawingView.ReferencedDocumentDescriptor.ReferencedFileDescriptor.ReplaceReference(strFileName)
FileDescriptor.ReplaceReference Method
Parent Object: FileDescriptor
Description
Method that replaces the referenced file.
Syntax
FileDescriptor.ReplaceReference( FullFileName As String )
Parameters
Name Description
FullFileName Input string that specifies the full file name to which the reference should be switched.
Remarks
The file being replaced and the replacement file must share ancestry (i.e. they must have the same InternalName). Documents have the same internal name if they are copied using 'Save Copy As' or a file explorer copy.
Version
Introduced in Inventor version 11
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
MechMachineMan
If nothing else is working, just recreate what you do manually using the code; ie moving sheets/drawing views/replacing reference in a new file..
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Jef_E
I know, but I feel it should be possible in the way my code intends to. So that why I ask if I am doing something wrong or what I should change. If someone from Autodesk verifies it's not possible I will do the whole copy hassle..
@johnsonshiue @ekinsb @adam.nagy
Inventor 2014 SP2
frederic.vandenplas
@Jef_E i had the same issues, and i actually recreated the manual labour in code
I use this tool a lot to avoid the workaround
Sub ReplaceView()
Dim oDoc, oDocTemp As DrawingDocument
Set oDoc = ThisApplication.ActiveDocument
Set oDocTemp = ThisApplication.Documents.Add(kDrawingDocumentObject)
Dim oDrawingView, oDrawingViewTemp As DrawingView
Set oDrawingView = oDoc.SelectSet.Item(1)
Dim strDrawingViewName As String
strDrawingViewName = oDrawingView.Name
Call oDrawingView.CopyTo(oDocTemp.ActiveSheet)
oDrawingView.Delete
oDocTemp.Activate
Set oDrawingViewTemp = oDocTemp.ActiveSheet.DrawingViews(1)
Dim fd As FileDialog
Call ThisApplication.CreateFileDialog(fd)
fd.ShowOpen
Call oDrawingViewTemp.ReferencedDocumentDescriptor.ReferencedFileDescriptor.ReplaceReference(strFileName)
oDocTemp.Update2
Call oDrawingViewTemp.CopyTo(oDoc.ActiveSheet)
Call oDocTemp.Close(True)
Call oDoc.Activate
oDoc.Update2
End Sub
If you think this answer fullfilled your needs, improved your knowledge or leads to a solution,
please feel free to "kudos"
frederic.vandenplas
@Jef_E i don't think the behaviour of the API is different then the Replace Model Reference in this case...
