- Mute
- Permalink
- Report
is there a way to perform this action (replace Style) in the part document, but by code?
i could not find a command for Replacing a text style. But i found a way to delete the style and copy the other. it works like this:
Dim originalStyleName As String = "ReplaceMe" Dim replaceBy As String = "replaceWithMe" Dim doc As PartDocument = ThisDoc.Document Dim def As PartComponentDefinition = doc.ComponentDefinition Dim textStyleOrg As TextStyle = Nothing Dim textStyleNew As TextStyle = Nothing For Each style As TextStyle In doc.TextStyles If (Style.Name = originalStyleName) Then textStyleOrg = Style End If If (Style.Name = replaceBy) Then textStyleNew = Style End If Next textStyleOrg.Delete() textStyleNew.Copy(originalStyleName)
Jelte de Jong
Blog: hjalte.nl - github.com
Hello JelteDeJong,
thanks for your response, unfortunately I can't delete styles which are in use.
This will throw an exception:
As far as I know there's no way to create a "Standard" like for the drawing styles, and set that new standard as the active one. Then I would be able to delete the old style...
Hello Patrick1323,
I don't know what you want exatly, but could it be a solution to redefine the Style in Style library as you want and then Update the Stile from Style library?
extStyleOrg.UpdateFromGlobal()Best Regards
Wolfgang
does this work for you:
Dim originalStyleName As String = "Note Text (ANSI) - 3DA" Dim replaceBy As String = "Sketch Text (ANSI) - 3DA" Dim doc As PartDocument = ThisDoc.Document Dim def As PartComponentDefinition = doc.ComponentDefinition Dim textStyleOrg As TextStyle = Nothing Dim textStyleNew As TextStyle = Nothing For Each style As TextStyle In doc.TextStyles If (Style.Name = originalStyleName) Then textStyleOrg = Style End If If (Style.Name = replaceBy) Then textStyleNew = Style End If Next ' in this part all properties from textStyleNew are copyed to textStyleOrg Dim type As Type = GetType(Inventor.TextStyle) For Each prop As Reflection.PropertyInfo In type.GetProperties() If (prop.CanWrite) Then If (prop.Name = "Name" Or prop.Name = "_Name") Then Continue For End If Dim obj = prop.GetValue(textStyleNew) prop.SetValue(textStyleOrg, obj) End If Next ' both styles are now the same.
Jelte de Jong
