Remove VBA code
Remove VBA code
RobJV
Remove VBA code
RobJV
Many years ago, I used to place VBA in my sheet metal template.   I am now working on a project that started with a "copy design" of one of these assemblies with code embedded in the parts. It is quite a nightmare as it takes forever to load among other issues.  I have gone through many of the parts and manually removed module2 which contains the offending code but is there an easier way?
Rob
dano0310
Hi I had the same problem with an autosave macro in my part files.
Sub Delete_AutoSave()
    Dim oApp As Application
    Set oApp = ThisApplication
    Dim VBProj, VBComp, CodeMod, ProcName, vbext_pk_Proc, StartLine, NumLines
     Set VBProj = oApp.VBAProjects
     Dim i, j
     For i = 1 To VBProj.count
        If VBProj(i).ProjectType <> kApplicationVBAProject Then
            For j = 1 To VBProj(i).InventorVBAComponents.count
                If VBProj(i).InventorVBAComponents(j).Name = ("AutoSave1") Then
                    Set VBComp = VBProj(i).InventorVBAComponents("AutoSave1").VBComponent
                    Set CodeMod = VBComp.CodeModule
                    ProcName = "AutoSave"
        With CodeMod
            StartLine = .ProcStartLine(ProcName, vbext_pk_Proc)
            NumLines = .ProcCountLines(ProcName, vbext_pk_Proc)
            .DeleteLines StartLine:=StartLine, count:=NumLines
        End With
            Next j
    Next i
End Sub
The module name was AutoSave1 and the sub was AutoSave from memory.  Give this a try and let me know if it works.  I have another one there which does a similar thing if it doesn't.
Dan
RobJV
Hi Dan,
Thanks for the code - I will give it a try when i am back on that project.  Without delving into the code, I assume that I can run that from the parent assembly?
Rob
RobJV
I tried it out but did not seem to do anything?
dano0310
Hi After going back over it the last one only deletes it out of the active file.
Mind the slopy programming I'm an engineer not a programmer.
This one should iterate through a few levels of assemblies and delete the "Autosave" sub from the "Autosave1" module
Sub Delete_AutoSave_In_All_Docs()
     Dim k As Integer
     For k = 1 To oApp.FileManager.Files.count
        If oApp.FileManager.Files(k).AvailableDocuments(1).DocumentType = kAssemblyDocumentObject Then
        Dim oFile As Document
        Set oFile = oApp.Documents.Open(oApp.FileManager.Files(k).FullFileName)
     Dim i, j
                    If CodeMod.countoflines > 10 Then
        With CodeMod
        End With
            Next j
    Next i
    'oFile.Close False
    Next k
End Sub
Let me know if this one works.
Dan
