- Mute
- Permalink
- Report
I wrote some code that can go through all my referenced documents, change the job number of the item, save it, and then delete the old file.
However this causes all the links in my assemblies to break. I know there is a FileDecriptor.ReplaceRefrence command, but I do not know how to make sure that the FileDesctriptor is the same document as the on in AllReferencedDocuments.
Because I am using a for each loop, I don't know how to address the FileDescripters enum.
Here Is the code I have so far
If ThisApplication.ActiveDocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then MsgBox("please only use on an assembly") Exit Sub End If Dim oDoc As AssemblyDocument = ThisApplication.ActiveDocument Dim sOldProjectNumber As String = InputBox("Enter old project number", "Old Number",) Dim sNewProjectNumber As String = InputBox("Enter new project number", "New Number") Dim oRefDoc As Document For Each oRefDoc In oDoc.AllReferencedDocuments Dim sOldName As String = System.IO.Path.GetFileName(oRefDoc.FullFileName) If sOldName.Contains(sOldProjectNumber) Then Dim sPath As String = System.IO.Path.GetDirectoryName(oRefDoc.FullFileName) Dim sNewName As String = sOldName.Replace(sOldProjectNumber, sNewProjectNumber) Try Dim oRefPropSet As PropertySet = oRefDoc.PropertySets.Item("Design Tracking Properties") Dim oRefProp As [Property] = oRefPropSet.Item("Part Number") oRefProp.Value = sNewName Catch MsgBox(System.IO.Path.GetFileName(oRefDoc.FullFileName)) End Try oRefDoc.SaveAs(sPath & "\" & sNewName, True) Dim oDocDesc As FileDescriptor = oDoc.ReferencedDocumentDescriptors.Item(oRefDoc) oDocDesc. System.IO.File.Delete(sPath & "\" & sOldName) End If Next
