Relink references to renamed files
MTheDesigner
MTheDesigner
I wrote some code that can go through all my referenced documents, change the job number of the item, save it, and then delete the old file.
However this causes all the links in my assemblies to break. I know there is a FileDecriptor.ReplaceRefrence command, but I do not know how to make sure that the FileDesctriptor is the same document as the on in AllReferencedDocuments.
Because I am using a for each loop, I don't know how to address the FileDescripters enum.
Here Is the code I have so far
If ThisApplication.ActiveDocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then
	MsgBox("please only use on an assembly")
	Exit Sub
End If
Dim oDoc As AssemblyDocument = ThisApplication.ActiveDocument
Dim sOldProjectNumber As String = InputBox("Enter old project number", "Old Number",)
Dim sNewProjectNumber As String = InputBox("Enter new project number", "New Number")
Dim oRefDoc As Document
For Each oRefDoc In oDoc.AllReferencedDocuments
	Dim sOldName As String = System.IO.Path.GetFileName(oRefDoc.FullFileName)
	If sOldName.Contains(sOldProjectNumber) Then
		Dim sPath As String = System.IO.Path.GetDirectoryName(oRefDoc.FullFileName)
		Dim sNewName As String = sOldName.Replace(sOldProjectNumber, sNewProjectNumber)
		Try
			Dim oRefPropSet As PropertySet = oRefDoc.PropertySets.Item("Design Tracking Properties")
			Dim oRefProp As [Property] = oRefPropSet.Item("Part Number")
			oRefProp.Value = sNewName
		Catch
			MsgBox(System.IO.Path.GetFileName(oRefDoc.FullFileName))
		End Try
		oRefDoc.SaveAs(sPath & "\" & sNewName, True)
		Dim oDocDesc As FileDescriptor = oDoc.ReferencedDocumentDescriptors.Item(oRefDoc)
		oDocDesc.
		System.IO.File.Delete(sPath & "\" & sOldName)
	End If
Next
JelteDeJong
you could use the AllReferencedOccurrences. Some thing like this:
Dim doc As AssemblyDocument = ThisDoc.Document
Dim def As AssemblyComponentDefinition = doc.ComponentDefinition
For Each refDoc As Document In doc.AllReferencedDocuments
	Dim newDoc As Document = CreateNewDoc(refDoc)
	Dim occs = def.Occurrences.AllReferencedOccurrences(refDoc)
	For Each occ As ComponentOccurrence In occs
		occ.ReferencedFileDescriptor.ReferencedDocument(....)
	Next
Next
Jelte de Jong
Blog: hjalte.nl - github.com
MTheDesigner
Hey @JelteDeJong Thanks for responding.
I have a couple of questions regarding how your implementation works.
where are you accessing this CreateNewDoc command from, or is this supposed to be a reference to my code doing this?
Can you use a document to select an occurrence? The argument says it should be looking for a component occurrence.
I don't know what .... means. Is this an operator or is this where I am supposed to put my new document
Curtis_Waguespack
Hi @MTheDesigner
I think you might get by with just using SaveAs to create the copies and swap out the references, see your other thread for an example:
https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/what-are-the-rules-for-links-and-ren...
I hope this helps.
Curtis
