Regenerate specific rule
dg2405
dg2405
With the following Command i can regenerate all rules:
Dim controlDef as ControlDefinition = ThisApplication.CommandManager.ControlDefinitions.Item("iLogic.RegenAllRules")
controlDef.Execute2(True)
 But is there a function to only regenerate a specific rule, the same thing like rmb on a rule and regenerate it.
Sergio.D.Suárez
Hi, what programming environment are you working on?
If this is in ilogic, have you tried the following shortcuts?
iLogicVb.RunExternalRule("ruleFileName")
 To run it for a sub-part:
iLogicVb.RunExternalRule("PartA:1", "ruleFileName")
 Grettings!
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
