REFERENCE IPROPERTY IN ASSEMBLY OF FIRST VIEW IN A DRAWING
SECOJOSE
SECOJOSE
This should be simple a simple request. Im looking for how to reference a custom property of the assembly in the first view of a drawing.
Replies (8)
nstevelmans
Hi, this could be a start
If the first view reference is an assembly document and if the assembly document references a custom property a message box will appear with value.
   Sub main
	   Dim CustomProp As String = "CustompropName" 'property to be found change this
        Dim oDrawDoc As DrawingDocument = ThisApplication.ActiveDocument
        Dim oSheet As Sheet = oDrawDoc.ActiveSheet
		If oSheet.DrawingViews.Count = 0 Then Exit Sub
        Dim oView As DrawingView = oSheet.DrawingViews.Item(1) 'firts view to be found
        Dim oDoc As Document = oView.ReferencedDocumentDescriptor.ReferencedDocument
        If oDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
            Dim oCustomprop As Inventor.Property = GetCustomprop(oDoc, CustomProp)
            If oCustomprop IsNot Nothing Then
                Dim oCustompropValue As String = oCustomprop.Value
                MsgBox(oCustompropValue)
            End If
        End If
	End Sub
		 Private Function GetCustomprop(AssyDoc As AssemblyDocument, CustomProp As String) As Inventor.Property
        Dim result As Inventor.Property = Nothing
        Try
            ' Get the PropertySets object.
            Dim oPropSets As PropertySets = AssyDoc.PropertySets
            ' Get the design tracking property set.
            Dim oPropSet As Inventor.PropertySet = oPropSets.Item("Inventor User Defined Properties")
            ' Get the part number iProperty.
            Dim oPartNumiProp As Inventor.Property = oPropSet.Item(CustomProp)
            result = oPartNumiProp
        Catch ex As Exception
        End Try
        Return result
    End Function
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
bradeneuropeArthur
Is this what you mean?
Arthur Knoors
Autodesk Affiliations:
bradeneuropeArthur
Arthur Knoors
SECOJOSE
Im looking for something similar to the parameter snippet:
Parameter("ASSYNAME.iam.PARAMETERNAME")
But im trying to call a property of the assembly instead of a parameter. Is that much code required for something like the above for properties?
WCrihfield
Hi @SECOJOSE.  I think you are looking for something like this:
Dim sTitle As String = iProperties.Value("22240287.iam", "Summary", "Title")
Logger.Info(sTitle)
...where "22240287.iam" is the file name, with file extension, of the assembly being referenced in your drawing.  This type of iLogic shortcut snippet can 'reach' any document that is being referenced by the current document that the rule is acting upon.  The "Summary" is associated with which PropertySet the iProperty is located within, then the "Title" is the name of the iProperty.  Just change those as needed.
Wesley Crihfield
(Not an Autodesk Employee)
SECOJOSE
Thats what i needed.
Im trying to make the description of a drawing file match the description of the model in the first view, however, the model has multiple model states. The way this snippet works now is that it will grab the description of the model state the model was saved in. Is there a way to specify which model state to pull the description from?
WCrihfield
Hi @SECOJOSE.  I'm still using Inventor Pro 2024.3, and there is nothing within the standard iLogic 'snippets' that suggests a way to specify a specific ModelState for this code to focus on yet.  I know that in 2025 some advancements were made to give us more control over how those 'simplistic' iLogic shortcut snippets access documents with multiple ModelStates in them, but I thing that additional control is mainly focussed on whether your 'edits' will effect only the 'active' ModelState or 'all' ModelStates in the target document.  I am not sure if they added a way to say which specific ModelState you want it to read from / write to with that code tool.  There are also multiple other uncertainties (not well documented anywhere) about how that simplistic code tool will work in different situations.
You could try replacing the regular file name, with extension with "22240287.iam (Model State1)", where the name of the ModelState is included at the end, after a single space, and within ( & ) symbols, like how it appears in the Document.DisplayName value, when representing a ModelState member.
However, then the whole issue of factory vs member thing comes into play.  We can usually read or write to the 'factory' version of a model document, but can only read from member versions of the document.  There is only a 'factory' when there are 2 or more ModelStates present, and the factory is simply the document associated with whichever ModelState happens to be 'active' at that time.
Wesley Crihfield
SECOJOSE
Thank you very much for your help. Its unfortunate about the lack of control with model states, but im going to try a workaround involving a program that opens the model, changes the model's model state to the model state presented in the view, saving it, then updating the description. Not the most elegant solution but hopefully it will tie me over until Autodesk catches up.
Thanks again
