Reading Autodesk Inventor dialogs with Python
jonzavialov
jonzavialov
I am working on a project with a lot of .iam files. Sometimes these files are missing, causing the following dialog to show up when I try to open files that use this assembly:
I am trying to create a python program that will create a COM object with Autodesk Inventor, open the file in question, and check that all the assemblies it uses are present. I want to do this by detecting if Inventor throws an error after trying to open the file.
Here is my code so far:
import win32com.client
from win32com.client import gencache
import time
import threading
import pythoncom
from tqdm import tqdm
WAITTIME = 5
def check_file(id, result, verbose, done):
    pythoncom.CoInitialize()
    oApp = win32com.client.Dispatch(
        pythoncom.CoGetInterfaceAndReleaseStream(id, pythoncom.IID_IDispatch)
    manager = oApp.ErrorManager
    if verbose:
        with tqdm(total=WAITTIME, desc="Waiting") as pbar:
            for i in range(WAITTIME):
                if done[0]:
                    result[0] = False
                    oApp.Quit()
                    return
                pbar.update(1)
                time.sleep(1)
    else:
            if done[0]:
                result[0] = False
                oApp.Quit()
                return
            time.sleep(1)
    try:
        result[0] = manager.IsMessageSectionActive
        oApp.Quit()
    except:
        pass
def file_is_broken(link, verbose=False):
    oApp = win32com.client.Dispatch('Inventor.Application')  # get COM object
    oApp_id = pythoncom.CoMarshalInterThreadInterfaceInStream(pythoncom.IID_IDispatch, oApp)
    mod = gencache.EnsureModule('{D98A091D-3A0F-4C3E-B36E-61F62068D488}', 0, 1, 0)  # Loads python support
    oApp = mod.Application(oApp)
    result = [None]
    done = [False]
    thread = threading.Thread(target=check_file, args=(oApp_id, result, verbose, done,))
    thread.start()
    try:
        oApp.Documents.Open(link)
        done[0] = True
        thread.join()
    except:
        pass
    return result[0]
if __name__ == "__main__":
    print(file_is_broken("<FILE PATH>", True))
What I am doing is creating the COM object, opening the file from its path, waiting a couple seconds, and then checking to see if there is an error present in another thread while the document is opening. This works, however it is not exact because there can be different errors and I only want to check if the "Resolve Link" error is present so I can determine that the file has broken links.
Is there a way for me to read the contents of the dialog through the Inventor API COM object, so I can get more information about the error that is present?
A.Acheson
Hi @jonzavialov
Not relating to reading the inventor dialogues but you can check the assembly for missing file references. See this post.
Regards
Alan
jonzavialov
Unfortunately the project constraints say that the language has to be Python, is there any way to achieve the same thing in Python?
A.Acheson
Hi @jonzavialov  it will require translation and I have no expieriece with python but if you have already opened the document in pyton using inventor app then you have 60% done. It may be the easiest to stick with the referenced document than the occurrences.
VB.NET Example from this thread
Sub Main
     Dim MissingRefFound As Boolean = False
     CheckMissingDocDescriptors(ThisApplication.ActiveDocument)
        If MissingRefFound Then
            MessageBox.Show("Missing ref found")
End Sub
Sub CheckMissingDocDescriptors(oAssyDoc As Inventor.Document)
        Dim oRefDoc As Inventor.DocumentDescriptor
        For Each oRefDoc In oAssyDoc.ReferencedDocumentDescriptors
                Exit Sub
            If Not oRefDoc.ReferenceSuppressed Then
                If oRefDoc.ReferenceMissing Then
                    MissingRefFound = True
                Else
                    CheckMissingDocDescriptors(oRefDoc.ReferencedDocument)
        Next
    End Sub
Regards
Alan
JelteDeJong
doc = ThisApplication.ActiveDocument
for refDocDescriptor in doc.ReferencedFileDescriptors:
    if refDocDescriptor.DocumentFound == False:
        print("Un resolved reference found")
Jelte de Jong
Blog: hjalte.nl - github.com
Frederick_Law
That dialog is not missing files.
That's duplicated files in different folders.
For example, someone created an assembly with Part1 to Part10 in one folder.
Another day created another assembly with Part1 to Part10 in another folder.
Someone open both assemblies at the same time and files got mixed up.
