read iproperties
read iproperties
good morning.
i am begining with autocad programation, i need read personnal propertu to add to database. i have to open file in disk without open inventor to read data from file. i use c# and i can use vb.net if obligatory
any one can help me to do that
thank
johnsonshiue
Hi! Please take a look at the following thread. You will need to use Apprentice Server.
https://forums.autodesk.com/t5/inventor-customization/how-to-compare-two-document-internal-name-with...
Many thanks!
Software Test Engineer
thank you very match
i solved that creating a tool with c# all is ok
thank sir
