Announcements
Rangebox without workfeatures
I have a macro that uses the rangebox of a partdocument to calculate the dimensions of that part to display in a partslist. The problem is that when there is a visible workplane or workaxis present in the part, the rangebox includes that workfeature and the part dimensions are not correct. I know I can also use the rangebox of the first solid in the part, but when it is a multibody part the dimensions will also not be correct.
Is there a way to get the rangebox of a part without the workfeatures? Or is there a some other good solution to get the outer dimensions of a part?
Replies (9)
Try pasting this code into an iLogic rule and running it. It's quick and dirty but it may inspire you into the right direction. It will turn off work features, measure the bounding box, pop up a message box with the outside dimensions, then reset your work features back to visible. It worked for me with multi-body parts and work features. Good Luck.
ThisApplication.CommandManager.ControlDefinitions.Item("AppAllWorkfeaturesCmd").Execute
Dim Length As Decimal = 0.0
Dim Height As Decimal = 0.0
Dim Width As Decimal = 0.0
Length = Measure.ExtentsLength
Height = Measure.ExtentsHeight
Width = Measure.ExtentsWidth
Dim SLength As String = Length.ToString()
Dim SHeight As String = Width.ToString()
Dim SWidth As String = Height.ToString()
MessageBox.Show("Complete" & vbLf & "Length: " & SLength & vbLf & "Width: " & SWidth & vbLf & "Height: " & SHeight, "Get Size")
I already tried that approach and it seems to work, however there is one problem. When a user already turned the workfeatures off, the first line of your code will actually enable the workfeatures again.
Is there a way to check if the workfeatures are already turned off? There doesn't seem to be proper API support for this (hence the command execution instead of using an API method). Iterating through all workfeatures and check there visibility is to time consuming for a macro that runs every time a part is saved....
Daniel
Thats strange because when I run it, it turns off all features, displays the message box, then only turns on the features that were on before I ran the rule.
Im not sure how to run through the entire browser and check all the work features.
It's strange that it works different for me than it does for you. I'm on Inventor 2015. Maybe if you're in an earlier version something has been changed.
Edit: Have you tried running the exact script I posted?
The command you execute, turning off the workfeatures, can also be run manually by the user (see attached image). When a user has all workfeatures turned off this way your code actually turns on the workfeatures first and turns them off when the code finishes.
See the attached animated gif.
Notice the rule does not behave for me like you are describing.
ekinsb
There are two potential solutions that I can see.  One is to continue the approach you're currently taking but use the API to control the visibility of the work geometry.  The following code demonstrates turning them off and then back on.  It's not just toggling them, which is what the command does but instead you are specifically specifying if they should be on or off.
Public Sub VisibilityTest()
    Dim doc As PartDocument
    Set doc = ThisApplication.ActiveDocument
    doc.ObjectVisibility.AllWorkFeatures = False
    doc.ObjectVisibility.AllWorkFeatures = True
End Sub
The second approach is to be indendent of the work feature display and just work with the range of the bodies.  The code below computes a range box that's the combination of all of the bodies in a part.
Public Sub GetBodyRange()
    Dim bodies As SurfaceBodies
    Set bodies = doc.ComponentDefinition.SurfaceBodies
    ' Initialize the range with the first body.
    Dim allRange As Box
    Set allRange = bodies.Item(1).RangeBox
    Debug.Print "(" & Format(allRange.minPoint.X, "0.000000") _
                & ", " & Format(allRange.minPoint.Y, "0.000000") _
                & ", " & Format(allRange.minPoint.Z, "0.000000") _
                & ")-(" & Format(allRange.maxPoint.X, "0.000000") _
                & ", " & Format(allRange.maxPoint.Y, "0.000000") _
                & ", " & Format(allRange.maxPoint.Z, "0.000000") & ")"
    ' Expand the range using any additional bodies.
    Dim i As Integer
    For i = 2 To bodies.Count
        Dim bodyRange As Box
        Set bodyRange = bodies.Item(i).RangeBox
        Dim minPoint As Point
        Dim maxPoint As Point
        Set minPoint = allRange.minPoint
        Set maxPoint = allRange.maxPoint
        If bodyRange.minPoint.X < allRange.minPoint.X Then
            minPoint.X = bodyRange.minPoint.X
        If bodyRange.minPoint.Y < allRange.minPoint.Y Then
            minPoint.Y = bodyRange.minPoint.Y
        If bodyRange.minPoint.Z < allRange.minPoint.Z Then
            minPoint.Z = bodyRange.minPoint.Z
        If bodyRange.maxPoint.X > allRange.maxPoint.X Then
            maxPoint.X = bodyRange.maxPoint.X
        If bodyRange.maxPoint.Y > allRange.maxPoint.Y Then
            maxPoint.Y = bodyRange.maxPoint.Y
        If bodyRange.maxPoint.Z > allRange.maxPoint.Z Then
            maxPoint.Z = bodyRange.maxPoint.Z
    Next
    allRange.minPoint = minPoint
    allRange.maxPoint = maxPoint
End Sub
Brian Ekins
Mod the Machine blog
Thanks Brian!
This is something I can use, as always you are a great help.
Daniel
el_jefe_de_steak
Here is a more simple version of the code:
Dim dims(0 To 2) As Decimal
dims(0) = Measure.ExtentsLength
dims(1) = Measure.ExtentsHeight
dims(2) = Measure.ExtentsWidth
MessageBox.Show("Complete" & vbLf & "Length: " & dims(0).ToString & vbLf & "Width: " & dims(1).ToString & vbLf & "Height: " & dims(2).ToString, "Get Size")
dba78
I'm not sure, since when this is available, as of Inventor 2020.3 the SurfaceBody object has a(n undocumented) Property: 'OrientedMinimumRangeBox'. This provides an 'OrientedBox' (introduced in Inventor 2016 - API help says).
The OrientedBox Object consists of a CornerPoint and 3 vectors. The length of these gives you the Extent of the SurfaceBody in these 3 directions independent of the XYZ-Orientation.
Since there is apparently no Add Method, in multibody environments you will need to create a surfacebody by BRep and call the property on that temporary body.
Something like this (VBA):
'requires a part open with 2 SolidBodies
Sub getSurfaceBody()
Dim cd As PartComponentDefinition
Set cd = doc.ComponentDefinition
Dim body1 As SurfaceBody
Dim body2 As SurfaceBody
Set body1 = ThisApplication.TransientBRep.copy(cd.SurfaceBodies(1))
Set body2 = ThisApplication.TransientBRep.copy(cd.SurfaceBodies(2))
ThisApplication.TransientBRep.DoBoolean body1, body2, kBooleanTypeUnion
Dim box As OrientedBox
Set box = body1.OrientedMinimumRangeBox
'Code below is just for graphical illustration :-)
Dim sk As Sketch3D
Set sk = cd.Sketches3D.Add
Set p0 = box.CornerPoint.copy
sk.Edit
Set p1 = p0.copy
p1.TranslateBy box.DirectionOne
sk.SketchLines3D.AddByTwoPoints p0, p1, False
Set p1 = p0.copy
p1.TranslateBy box.DirectionTwo
Set p1 = p0.copy
p1.TranslateBy box.DirectionThree
sk.ExitEdit
End Sub
For C# you will need to cast the SurfaceBody to dynamic type to make this work (don't expect intellisense to assist you:winking_face:)
var orientedBox = ((dynamic)body).OrientedMinimumRangeBox;
