"Active Document is Not a Part Document" Issue in Autodesk Inventor
svloFNWW9
Observer Observer
svloFNWW9
Observer
Observer
Dear all,
I hope this message finds you well. I am writing to seek assistance regarding an issue I’ve encountered while trying to programmatically interact with Autodesk Inventor via Python scripts using the Inventor API.
Problem Description
While attempting to process a Part Document (.ipt) using the API, the script consistently returns the following error:
"Active document is not a Part Document. Please open a Part (.ipt) file."
What I Have Tried
  1. Verified that the correct file (Part.ipt) is located in the target directory.
  2. Manually opened the Part Document in Autodesk Inventor before running the script.
  3. Attempted to explicitly activate the Part Document in the script using:
    python
    Copy code
    part_doc = inventor_app.Documents.Open(part_file_path) inventor_app.ActiveDocument = part_doc
  4. Confirmed the document type with:
    python
    Copy code
    part_doc.DocumentType
    The result is 12290, which doesn’t match the expected value for a Part Document (2).
Environment Details
  • Autodesk Inventor Version: 2025
  • Python Version: 3.13.1
  • Operating System: Windows 11 Pro
  • API/Library: PyWin32 for COM interaction
Expected Behavior
The script should identify the active document as a Part Document and proceed with further processing without errors.
Request for Assistance
Could you please advise on:
  1. Whether the document type 12290 indicates a specific issue or misconfiguration?
  2. Steps to ensure the Part Document is correctly recognized by the API.
  3. Any additional settings or adjustments required in Autodesk Inventor for seamless API interaction.
If necessary, I can provide sample code or additional details about the environment and workflow.
Thank you for your time and support. I look forward to your guidance on resolving this issue.
Best Regards,
A.Acheson
Hi @svloFNWW9
I would have thought it unnecessary to set the active document = to itself as this might have unintended outcome.
For the number this is the enum value for the part document which checks out.
kPartDocumentObject12290Part Document
You should be able to use from this point on
The set variable part_doc
Regards
Alan
marcin_otręba
I  do not know python but i do not really understand if you did it correctly here :
part_doc = inventor_app.Documents.Open(part_file_path) inventor_app.ActiveDocument =part_doc
active document is read only:
maybe it should be :
Hi, maybe you want to vote my:
Ideas
or check my apps:
DrawingTools   View&ColoringTools   MRUFolders   auto-save-replace
C_Haines_ENG
The "Active Document" is the file that is currently selected and opened in Inventor. If that file is not a part document, you will get this error.
