Push add-in to all users
Majjek
Majjek
I've developed an add-in which is almost ready for distribution to all users in our company (~20 users).
What is the best way to do this?
Create an installer and then manually install it everywhere?
And after that, when I make changes, what is the best way to update everything?
Thanks in advance for your ideas.
Replies (10)
AlexFielder
Back in the day, it was possible (using Visual Studio) to "publish" an executable to a shared network location. You'll still see this on certain Windows applications; Google Chrome can do this (depending on where the installer originates).
I've built most of my installers using Innosetup - which is free and relatively simple to get going with; although I've never found an "update" mechanism that works aside from emailing my fellow users on the head and saying "there's an updated installer for {addinNameHere} available at {path}"
I would love to hear other's suggestions though.
bradeneuropeArthur
We have created a .bat file that starts with windows and copies the dll files each time windows starts!
Arthur Knoors
Autodesk Affiliations:
bradeneuropeArthur
like this:
@Anonymous off
xcopy "P:\xx\yy.dll" "C:\Program Files\Autodesk\Inventor 20##\Bin\" /y
xcopy "P:\xx\zz.dll" "C:\Program Files\Autodesk\Inventor 20##\Bin\" /y
xcopy "P:\xx\yy.addin" "C:\ProgramData\Autodesk\Inventor 20##\Addins\" /y
xcopy "P:\xx\zz.addin" "C:\ProgramData\Autodesk\Inventor 20##\Addins\" /y
Arthur Knoors
Majjek
Thanks for the program.
Majjek
This sounds like an easy solution, thanks!
bradeneuropeArthur
Your thanks are appreciated.
Sometimes we all forget to take a look at the easy way....
Arthur Knoors
frederic.vandenplas
I Copy the Addin file local (you can use the script provided here) and let that file point to the dll which is on the server, so if i need to update the dll, i just can overwrite it, next time users start up, the new version is loaded.
If you think this answer fullfilled your needs, improved your knowledge or leads to a solution,
please feel free to "kudos"
Majjek
That sounds even better.
Where is 'here' regarding to the script.
bradeneuropeArthur
P:\xx\yy
P:\xx\yy
P = the server
xx\yy is the path
Arthur Knoors
frederic.vandenplas
I was pointing to message 4 from @bradeneuropeArthur
