Property LibraryName (ReferencedFileDescriptor) in onSaveDocument-Event
IQUADRATAG
IQUADRATAG
I try to figure out, wether a component is member of an external library or not (e.g. Cadenas). As far as I know I have to use the property "LibraryName" wich is part of the ReferencedFileDescriptor. But how can I get fom a "Document"-Object to the ReferencedFileDescriptor?
Private Sub oAppEvents_OnSaveDocument(ByVal DocumentObject As Document, ByVal BeforeOrAfter As EventTimingEnum,                                            ByVal Context As NameValueMap, ByRef HandlingCode As HandlingCodeEnum) _                                           Handles m_oAppEvents.OnSaveDocument
' Ignore Content-Center
If DocumentObject.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
   Dim part As Inventor.PartDocument = DocumentObject
   If part.ComponentDefinition.IsContentMember Then
      HandlingCode = HandlingCodeEnum.kEventNotHandled
      Exit Sub
   End If
End If
' Ignore library-components.
Thank you in advance.
Greetings
Christian
Replies (0)
