Programmatically make the difference between Inventor & AutoCad .dwg
FINET_Laurent
Advisor Advisor
FINET_Laurent
Hi folks,
I have a list of .dwg files. I would like to remove the AutoCad .dwgs & keep the Inventor .dwg.
How can I make the difference between the two programmatically ?
Kind regards,
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
WCrihfield
Interesting issue.  Have you already checked tried opening each of them in Inventor, then using the DrawingDocument.IsInventorDWG property?  I have never tested it myself before, because we use IDW for all our drawings, so the only DWG's we have are from AutoCAD.
Wesley Crihfield
(Not an Autodesk Employee)
WCrihfield
Another one to test might be the ThisApplication.FileManager.IsInventorDWG() method, which will actually take a String type input, instead of having to open, then use a DrawingDocument object.
Wesley Crihfield
FINET_Laurent
Dear @WCrihfield
Kind regards,
FINET L.
