Problem with 2018 Inventor Samples referencing 2013 textures
Could someone at Autodesk please update the 2018 Inventor Sample files so they no longer contain references to 2013 textures which are not accessible?  Many of them have that problem which causes them not to be able to be checked into a test vault for the purposes of testing Inventor and Vault add-ons.
I've tried copying all of the 2018 textures to a similar 2013 path and then add the additional 2013 material library in the project editor, but it continues to show the same errors, even after doing that.
Here's where the 2018 Inventor sample files are currently downloadable from:
https://knowledge.autodesk.com/support/inventor-products/downloads/caas/downloads/content/inventor-s...
And here's the sort of errors that occur when attempting to check many of those samples into a test vault:
= Jeff =
Replies (0)
