Problem getting the Distance property in a DistanceChamfer via API
Hi there,
I am using Inventor 2018 and programming an addin in C++. I would like to access the 'Distance' property in a DistanceChamferDefPtr object but I am getting a _com_error exception.
 Snippet
ChamferFeaturePtr chamferFeature = chamferColl->GetItem(itChamfer);
if (chamferFeature == NULL)
    return;
ChamferDefinitionPtr chamferDef = chamferFeature->GetDefinition();
if (chamferDef->Type == kDistanceChamferDefObject) {
    DistanceChamferDefPtr distanceChamfer = chamferDef;
    if (distanceChamfer) {
        ParameterPtr distanceParam = distanceChamfer->Distance;
        double value1 = (double)distanceParam->Value;
        VARIANT_BOOL setBack = VARIANT_FALSE;
        setBack = distanceChamfer->CornerSetback;
        double angle = 45.000;
When I try to get the Distance or CornerSetback ParameterPtr is when the program raises the exception. Any clue where my problem could be located?
Regards
Mark.Lancaster
@Anonymous
Welcome to the Autodesk User's Community..
Although someone may come along and assist you..  Programming questions and needs should be asked in the Inventor Customization forum.  I will have the moderator relocate it there to better suit your needs.
Mark Lancaster
