Prevent display update while running rule
s342014
s342014
I'm working on an assembly where I use iLogic and Forms to update dimensions, constraints, and parts.
It all works well, but when I run my "Update rule", which updates all rules in the assembly, I want to prevent Inventor from  updating the display until all parts and settings are updated.
The closest I've come is using a suggestion I found on these forums earlier:
ThisApplication.ScreenUpdating = False
            ... some iLogic commands ...
ThisApplication.ScreenUpdating = True
However, this freezes the whole application, while I only want to prevent the assembly display to not update.
I've seen this being done on other assemblies, but cannot for the life of me figure out how it is done.
I hope I've stated my issue in an understandable way, please ask for additional info if that is needed.
JelteDeJong
This are the options that i know of that do something similar:
ThisApplication.AssemblyOptions.DeferUpdate
ThisApplication.UserInterfaceManager.UserInteractionDisabled
ThisApplication.SilentOperation
Jelte de Jong
Blog: hjalte.nl - github.com
s342014
Thank you for the answer.
As stated in my post, ThisApplication.UserInterfaceManager.UserInteractionDisabled does pretty much what I want done, but not exactly, as it locks the entire application (the icon even disappears from the Windows taskbar).
As of now, it seems this is the closest I can get, thank you for responding.
Even though your response comes close to solving my issue, I will not mark it as a solution, as I hope other users may give a "better" solution.
yan.gauthier
What I do in those case is to set InvApp visibility to false and display a progress bar to let know the user something is happening (example is in VBA)
Public Sub ASub()
Dim invapp As Inventor.Application
Dim progBar As ProgressBar
Dim MainAssembly As AssemblyDocument
Dim refDoc As Object
Set invapp = ThisApplication
On Error GoTo MyErr'Handle further error by exiting the sub
If TypeOf invapp.ActiveDocument Is AssemblyDocument Then
    Set MainAssembly = invapp.ActiveDocument
    Set progBar = invapp.CreateProgressBar(False, MainAssembly.AllReferencedDocuments.count, "ProgressBarName", False)
    invapp.Visible = False 'Hide inventor during routine
    For Each refDoc In MainAssembly.AllReferencedDocuments ' Get all referenced file in assembly
        progBar.UpdateProgress
        'do work!
    Next refDoc
Else
    MsgBox "Active File is not an Assembly"
MyErr:
If Err Then
    MsgBox "Unexpected error during routine: " & Err.description, Title:="RoutineName"
    Err.Clear
    invapp.Visible = True
    If Not progBar Is Nothing Then
        progBar.Close
    Exit Sub
progBar.Close
End Sub
