Prevent CER window (remove senddmp.exe?)
Majjek
Message 1 of 1
Majjek
We're running Inventor in automated environment, where it's been using to generate files.
The program controlling Inventor in that environment checks if the application is running and if it's not, fires up a new instance.
But whenever de CER window appears to send an error report (reason doesn't matter, it's random) it doesn't continue, because it probably still sees Inventor as being open.
I read somewhere that the senddmp.exe file in the Inventor\bin folder is showing this screen.
Since it's not easy to test this (you would have to create an error causing the CER window to appear) can anyone tell if renaming this file will prevent the popup from showing, and just close Inventor?
I know it's impossible to investigate what happened after an error, but in this case, it's not wanted.
Thanks in advance.
Replies (0)
