Press ESC to stop running ilogic code
karthur1
karthur1
I would like to be able to press ESC key while my ilogic rule is running and this will stop the program execution. Is there a way to do this? Would anyone have an example of a program with this feature in it?
WCrihfield
I agree somewhat.  We definitely need a quick & easy way to stop code execution in some scenarios.  This has been requested for some time now.  Maybe this will help boost support for the related Ideas in the Inventor Ideas forum.
https://forums.autodesk.com/t5/inventor-ideas/esc-key-stop-ilogic-script/idi-p/7406154
https://forums.autodesk.com/t5/inventor-ideas/esc-from-ilogic-editor-edit-rule/idi-p/7582347
https://forums.autodesk.com/t5/inventor-ideas/escape-endless-logic-loop/idi-p/8990847
https://forums.autodesk.com/t5/inventor-ideas/esc-key-stop-operation/idi-p/3733288
Wesley Crihfield
(Not an Autodesk Employee)
Michael.Navara
This question looks nice, but is very hard to implement. Because in some cases is not possible to interrupt  the execution. For example you can not interrupt execution inside transaction. More info.
You can implement the similar functionality using ProgressBar. See the following example
Sub Main
    Dim oSketetch As Sketch = ThisDoc.Document.ActivatedObject
    Dim linesCount = 1000
    DrawLinesInSketch(oSketetch, linesCount)
End Sub
Private progressBar As progressBar
Private cancelRequested As Boolean
Sub DrawLinesInSketch(oSketetch As Sketch, linesCount As Integer)
    'Initialze progress bar
    progressBar = ThisApplication.CreateProgressBar(False, linesCount, "Drawing lines", True)
    AddHandler progressBar.OnCancel, AddressOf ProgressBar_OnCancel
    'Draw lines to sketch
    For i As Integer = 1 To linesCount
        'Check if cancel opration is requested
        If cancelRequested Then
            Exit For
        End If
        progressBar.UpdateProgress()
        oSketetch.SketchLines.AddByTwoPoints(
        ThisApplication.TransientGeometry.CreatePoint2d(0, i),
        ThisApplication.TransientGeometry.CreatePoint2d(i, 0)
    Next
    'Cleanup progress bar
    RemoveHandler progressBar.OnCancel, AddressOf ProgressBar_OnCancel
    progressBar.Close()
    'Display final messageBox
        MsgBox("Canceled", MsgBoxStyle.Exclamation)
    Else
        MsgBox("Done", MsgBoxStyle.Information)
    End If
End Sub
Private Sub ProgressBar_OnCancel()
    cancelRequested = True
End Sub
For more complex task, which doesn't need Inventor for full time, you can use BackgroundWorker and use another thread for computing.
